Consider a simple circuit with a battery and a resistor, connected by wires.
We usually treat the wires (excluding the resistor) as ideal conductors (no resistance). Therefore, we conclude that the voltage drop happens across the resistor only, meaning that the potential across any two points of the same wire (either from one end of the battery up to the start of the resistor, or from the end of the resistor to the other end of the battery) is the same.
If the potential across a wire is constant, and the electric field is the derivative of the potential, it means the electric field on any point on the wire is zero.
If the electric field is zero, it means no electric force is acting on charges in the wires and accelerate them.
The charges in the wires do move, though, so it appears electric field does act on them. What am I missing?
Yiftach
  • 271
This is true in ideal circuit theory where, to model a physical wire with resistance, we actually add an ideal resistor to the circuit to account for the voltage drop across the physical wire (we can also add an ideal inductor for the self-inductance of the wire etc.)
For a physical circuit, the zero resistance wire is a good approximation in the case that the resistance of the connecting wires is insignificant compared to the total resistance.
Correct and, for the DC case that you've stipulated, this is exactly what we want otherwise the current would be changing in contradiction to the stationary assumption.
Why? In the previous quote, you correctly state that an electric field accelerates the (mobile) charge. But move is not a synonym for accelerated.
-1
You can think of $R$ as a parameter that models the resistance of the entire wire. In real circuits there is a nonzero electric field in every point of the wire, and each tiny section of the wire has some resitance.
slaaidenn
  • 584
-1
The problem here is that you give physical relevance and interpretation to the non-physical approximations of your model. A real wire has finite resistance and a finite voltage across it. However, if the resistance (and thus voltage) is very small in comparison to the voltages across other components then this voltage can be ignored to simplify calculation. The approximation of 'treat small voltages as zero' has no physical meaning for the components effected by these voltages, and as such trying to figure out how an object behaves with zero voltage across it is not the correct interpretation.
Eddy
  • 1,073
