Given the density $\rho$ and the movement speed $v$ of a liquid, we are asked to find its pressure.
The unit of pressure is $N/m^2$, of density it's $kg/m^3$, and then the unit of speed is $m/s$, the dimensions of our magnitudes would be $ML^{-1}T^{-2}$, $ML^{-3}$ and $LT^{-1}$.
From this, we can deduce that the formula relating pressure to speed and density, should be $P = \rho v^2$ times some constant $c$. Is there any way to find the constant, or is that impossible by using only dimensional analysis?
Dimensional analysis only gives you the dimensionality of a property from a set of linearly independent dimensions. Unfortunately, the constant is unable to be solved in these situations without more information.
Doug
  • 334
