17
In non-relativistic quantum mechanics, causality is violated by saying that the amplitude of propagation of a particle $$A=\langle \textbf{x}|\exp{\Big(\frac{-i\textbf{p}^2t}{2m\hslash}}\Big)|\textbf{x}_0\rangle$$ between any two points $\textbf{x},\textbf{x}_0$ is non-zero for any time $t$, however small.
But this is also true in quantum field theory. The amplitude of propagation of a particle from a spacetime point $x$ to another spacetime point $y$, given by $$A(x,y)=\langle 0|\phi(x)\phi(y)|0\rangle\neq 0$$ even for space-like separations.
Therefore, isn't by the previous argument, here too, causality violated?
This is "resolved'' in QFT by saying that we should not ask whether particles can propagate over spacelike intervals, but whether a measurement at $x$ can affect a measurement $y$ if their separation is spacelike, and when one computes $[\phi(x),\phi(y)]$ for $(x-y)^2<0$, it turns out that the commutator vanishes. So causality is preserved.
So my question is why do we take two different approaches to the "meaning of causality" in quantum mechanics and quantum field theory?
SRS
  • 27,790
  • 13
  • 115
  • 365
There are several misconceptions in this post. Let me address them one by one.
This is wrong on several different levels. First of all, in non-relativistic mechanics a process is acausal if and only if its amplitude is non-zero for $t<0$. Whether it vanishes or not for $t>0$ is irrelevant. Indeed, if $c\equiv \infty$ perturbations can propagate infinitely fast (cf. the heat equation), and this is not considered a violation of causality. The latter is violated if and only if effects are observed before their cause, i.e., if the amplitude is non-zero for negative times.
Second of all, your expression for $A$ is not a propagation amplitude; you forgot the step function (cf. wikipedia) $$ A=\langle \textbf{x}|\exp{\Big(\frac{-i\textbf{p}^2t}{2m\hslash}}\Big)|\textbf{x}_0\rangle\Theta(t) $$
Now you can see that $A$ vanishes for $t<0$, so the amplitude is causal, as required. So far so good.
No, this is not correct. The object $\langle 0|\phi(x)\phi(y)|0\rangle$ has nothing to do with a propagation amplitude, because the object $\phi(y)|0\rangle$ does not represent a particle localised at $y$. You already know that. A (non-) vanishing $A(x,y)$ has nothing to do with causality.
No, because the first $A$ represents a completely different object from the second $A$. Use the same letter if you want, but you are dealing with two different objects.
This is somewhat correct, but far from being the whole story. Let me quote a paragraph from Weinberg's QFT (page 198):
The condition $(5.1.32)$ is often described as a causality condition, because if $x-y$ is space-like then no signal can reach $y$ from $x$, so that a measurement of $\psi_\ell$ at a point $x$ should not be able to interfere with a measurement of $\psi_{\ell'}$ or $\psi^\dagger_{\ell'}$ at point $y$. Such a consideration of causality are plausible for the electromagnetic field, any of whose components may be measured at a given spacetime point, as shown in a classic paper of Bohr and Rosenfeld. However, we will be dealing here with fields like the Dirac field of the electron that do not see in any sense measurable. The point of view taken here is that Eq.$(5.1.32)$ is needed for the Lorentz invariance of the $S$-matrix, without any ancillary assumptions about measurability or causality.
where $(5.1.32)\equiv [\psi_\ell(x),\psi_{\ell'}(y)]=[\psi_\ell(x),\psi^\dagger_{\ell'}(y)]=0$ for $x-y$ space-like.
We do not. Causality is just the statement that the effect comes after the cause. In non-relativistic mechanics every interval is time-like so you only have to worry about the step function. In relativistic mechanics, the propagation velocity of everything is finite so you have to worry about space-like intervals as well. But that's it.
In quantum mechanics, we work with a single-particle theory. That is, if we detect a particle, we know it is our one and only particle and nothing else. If this unique particle shows up at two events at a space-like separation, it means that it has travelled at superluminal distance and our theory violates causality.
However, later on we realize that there is no "quantum mechanics + relativity" without the introduction of a possibly infinite number of particles - this compells us to throw away single-particle quantum mechanics and the foundations of quantum field theory are laid instead. The operator $\phi(x)$ then does not correspond to the detection of any unique particle, but only to the detection of some particle from the virtually infinite ensemble of indistinguishable particles of the QFT.
In other words, finding an electron in the matter around you on Earth and at the same time in the matter on the Moon corresponds to $\langle 0| \psi (x) \psi(y) | 0 \rangle $ with $x-y$ spacelike. But that does not mean that the electron has jumped to moon superluminally, it is just a different electron.
Consequently, we must relax our conditions on causality to something different: If I make any measurement at event $x$, it will not influence the measurement at $y$ if $x-y$ is space-like; finding an electron on Earth does not influence finding it on the Moon at the same moment. The measurements which are mutually non-influencing are commuting in quantum mechanics, so we end up requiring $[\psi(x),\psi(y)] =0$ for $x-y$ space-like.
Void
  • 21,331
If the events $x$ and $y$ are at spacelike separation, then there is no Lorentz invariant notion of whether one event is earlier than the other, since there are transformations that reverse their temporal order.
To therefore speak of $\langle \phi(x)\phi(y)\rangle$ as the "amplitude for a particle to propagate from $x$ to $y$" is somewhat misleading - at least in some frames this sentence doesn't make any sense because $y$ is earlier than $x$, and they would tend to rather look at $\langle \phi(y)\phi(x)\rangle$. So both $\langle \phi(x)\phi(y)\rangle$ and $\langle \phi(y)\phi(x)\rangle$ essentially describe the same process - the propagation of a particle between the points $x$ and $y$ - and only the commutator is meaningful as looking at the sum/difference of these amplitudes.
Looking at only one of the amplitudes is like looking only at s-channel diagrams for some process and drawing all sorts of (wrong) conclusions from that.
ACuriousMind
  • 132,081
If we measure whether a particle has propagated, or an antiparticle has propagated, then there is a finite probability for propagation over spacelike separations. See Weinberg's Gravitation and Cosmology (Ch. 2 Sec. 13). In quantum field theory, in the context of S-matrix, measurements are made at spacial infinity from the interaction region whereas, for example, in neutrino oscillation experiments, the situation is very different. The source-detector distances can be small (17.6 m for KARMEN, and 30.0 m for LSND). When one looks at Weinberg's argument one finds that there is a non-zero probability for spacelike separations. But he dismisses it on the ground that for a proton such a distance is only 10^{-14} cm. But if one considers a particle of neV mass, then one gets a macroscopically large distance ~ 100 m! Very relevant for the LSND-KARMEN anomaly.
In the calculation of the propagator there are two terms: t > t' term and the other t<t' term -- when added together they cancel out for outside the light cone. But in LSND and KARMEN situations only one of the two terms are operative -- for S-matrix calculations both terms are operative.
Also, see Tony Zee's Quantum field theory in a nutshell, pp. 23 and 24 where he too argues for a propagation outside the light cone. In particular, theta(0) -- i.e. t=t' ignored by many authors.
