-2
I push my hand into a wall... The wall pushes at my hand. That's why I don't fall through the wall. BUT what if I get a sledgehammer and smash through the wall... Now all I see is Newton's third law working up until a point where the wall can't exert a big enough force to react against the sledgehammer.
So Newton's third law isn't universal?
Edit: wait guys, you are not making sense to me. But tell me if this is wrong or right. Is it because the wall pushes back against the sledgehammer with an equal and opposite force as they interact, but when the wall breaks it's just like the hammer is going through the air? Like the wall isn't there anymore?
What do you mean it only "works up to a point"?
You are correct that once the wall fails, the force felt may be reduced. But the force pair (force from the hammer onto the wall, and the force from the wall onto the hammer) continues to have identical magnitudes. It's not the case that one force continues to increase after the failure while the other decreases.
It doesn't say that swinging hard produces high forces. Only that the forces in both directions are of the same amount.
BowlOfRed
  • 42,997
  • 68
  • 123
This is a common misconception when learning Netwon's law. You aren't alone!
The trick to understanding how to apply Newton's law in situations involving walls and sledgehammers is to break free of our intuition regarding how much force a sledgehammer actually exerts. Intuitively, we tend to associate the force of a strike (such as that of a sledgehammer) with its maximum force -- the force it would exert against an immovable object. A sledgehammer can exert a lot of force like this. However, our intuition leads us astray here.
What actually happens is that the sledgehammer while it is impacting the wall, is exerting less than it's maximum force. In fact, it's exerting exactly the same force as the wall is exerting on it (Newton's Third Law in action). The result of those forces is that the hammer is decelerated by the force the wall applies on it, and the wall is driven backwards by the force of the hammer applied on it. This force accelerates the wall away from the sledgehammer.
When the wall breaks, that decreases how much force the wall can apply on the hammer, and thus by the 3rd law, how much force the hammer can apply on the section of wall directly in front of the head of the hammer. This lesser force is still used to accelerate the wall and its reaction is still decelerating the hammer. Given that there is likely very little material in front of the hammer and that it has been accelerated by the hammer already (before the wall fully broke), the amount of force applied here is very small. Almost the same as if the hammer was just flying through the air.
What this does mean is that if you tossed a feather in the air and then struck it with a sledgehammer, the sledgehammer would apply a very small force to the feather, and the feather would apply an equally small force to the hammer. The result would rapidly accelerate the feather up to the speed of the hammer, and would decelerate the hammer ever so slightly.
Beyond this, another thing that may help is to remember that striking events like these are not actually instantaneous. They can take a few milliseconds to occur, and the forces can change dramatically during that time. As an example, you can see how golf balls deform during impact when hit with a golf club. I find this helpful because a lot of the confusion that can happen learning Newton's laws comes from the idea of a strike happening instantaneously. In slow motion, you can see a lot more is going on!
Cort Ammon
  • 53,814
  • 103
  • 176
You apply an equal and opposite force on the wall still.
The force of the sledgehammer is greater than the "maximum force" the wall can handle and therefore exert (and this is pretty complicated and depends on material sciences and impact mechanics). Instead of stopping your hammer with equal force, it applies it's "maximum force".
This decelerates the sledgehammer; but it doesn't stop it completely. The sledgehammer can keep going through with decreased speed.
JMac
  • 15,595
