In non-relativistic physics, momentum defined as $p = mv $, so as object velocity increased, then the momentum increased. Or if mass of object increased/decreased, then the momentum too increased or decreased (as in rocket). And this concept very useful when discussing elastec collision between two object to determine how the state of both object after collision.
But in relativistic theory, momentum defined as $$ p = \frac{ m v}{\sqrt{1 - \frac{v^2}{c^2 }} } .$$ In this formulation, $m$ keeps constant, because there is no relativistics mass. So classical approximation for this variable is $$ \frac{ m v}{\sqrt{1 - \frac{v^2}{c^2 }} } \approx m v$$ or $$v_\text{rel} = \frac{ v}{\sqrt{1 - \frac{v^2}{c^2 }} } \approx v ,$$ because $m$ not changed as Einstein say.
So, what is physical meaning of this $v_\text{rel} $. Is it imply that $\textbf{ velocity }$ of object changed when its $\textbf{velocity}$ approach the velocity of light?
Edit: And what constitute $\gamma v $ for the planet orbiting the sun, if the mass stay constant?
