Today I half-remembered a wonderful trick to doing thermodynamical partial derivatives, but I neither recall the full set of rules, nor where I got them from! I was hoping someone else knows where they come from or where I can find them written out.
The rules, as far as I remember them, is to define a bracket $[A,B]$ defined on thermodynamical potentials and variables such that:
$[X,X] = 1$,
$[X,Y] = -[Y,X]$,
If $dX = AdB + CdD$, then $[X,Y] = [B,Y][D,Y]$,
and most importantly,
$\left(\frac{\partial X}{\partial Y}\right)_Z = \frac{[X,Z]}{[Y,Z]}$.
As an example of this working (I'm dropping the commas), we have
$$\left(\frac{\partial P}{\partial V}\right)_S = \frac{[PS]}{[VS]}\\ \\ = \frac{[PS]}{[VS]}\cdot \frac{[TP]}{[TP]}\cdot \frac{[TV]}{[TV]} \cdot \frac{[PP]}{[VV]} = \frac{[TP]}{[TV]}\cdot \frac{[HP]}{[TP]}\cdot \frac{[TV]}{[UV]}\\ \\ = \frac{[TP]}{[TV]}\cdot \frac{[HP]}{[TP]} / \frac{[UV]}{[TV]}\\ \\ = \left(\frac{\partial P}{\partial V}\right)_T \cdot \left(\frac{\partial H}{\partial T}\right)_P / \left(\frac{\partial U}{\partial T}\right)_V\\ \\ = \left(\frac{\partial P}{\partial V}\right)_T \cdot \left(\frac{C_p}{C_V}\right)$$
The second equality involves multiplying by 1 several times. The second is based on the third rule.
Edit:
As a user pointed out, the first identity is trivially wrong, and should be
$[X,X] = 0$.
For more details, see the link in the accepted answer.
The role of Jacobians in thermodynamics is presented nicely by Jaynes. It also contains the rules of manipulation. The physical meaning of Jacobian $\frac{[X,Y]}{[U,V]}$ in which $X,Y,U,V,$ are thermodynamic variables is as follows: Take an infinitesimal closed oriented thermodynamic path. The same path can be drawn on either $X$-$Y$ thermodynamic diagram or on $U$-$V$ thermodynamic diagram. The Jacobian $\frac{[X,Y]}{[U,V]}$ gives the ratio of oriented areas enclosed by the same thermodynamic path on the $X$-$Y$ and $U$-$V$ thermodynamic diagrams. In other words: \begin{align} \int dX~dY=\int dU~dV\frac{[X,Y]}{[U,V]} \end{align}
Deep
  • 6,642
