I have a fundamental misunderstanding about Airy wave theory. All the texts that derive the dispersion relation for gravity water waves use as a final step the unsteady Bernoulli equation: $$\frac{\mathrm d\Phi}{\mathrm dt} + g\eta = 0 .$$ But as far as I know, the unsteady Bernoulli equation also includes a squared-velocity term (and a pressure term that is constant), so it must indeed by written as $$\frac{\mathrm d\Phi}{\mathrm dt} + \frac12(v_x^2 + v_y^2) + g\eta = 0. $$ Now comes the point: if the fluid particles move in circles in constant speed, then the term $$\frac12(v_x^2 + v_y^2) $$ is also constant (like the atmospheric pressure) so the Bernoulli equation reduces to the familiar equation.
This assumption is indeed correct in deep water, but in intermediary water depth and shallow water it's not correct, but I have seen cases in which the Airy wave theory is also applied in this regimes. So what did I miss?
user2554
  • 547
O.K i think Nick P has explained to me the point very clearly. The velocity term in the unsteady Bernoulli equation is neglected for two reasons: the first and more important is that for waves with small slope $$ak$$ the velocity of the fluid elements is small in comparison with the wave speed (the ratio of their speed is equal to the wave slope), and since the wave speed is also not that high then the fluid elements speed is neglible , so the only important terms in Bernoulli equation are only the time derivative of the velocity potential and $$g\eta $$. The assumption that wave slope is small is the central linearization assumption of Airy wave theory, and is nessecery in order for that the Stokes drift will not be two large.
The second reason, which i mentioned in my question, is that even if we aren't neglecting the velocity of the fluid elements, we should take into account the change in their velocity, which in the case of deep water (circular trajectories) is zero. In the case of more shallow water the trajectories are flattened ellipses, but still the change in the velocity is small even in comparison with the velocity (of the elements) itself.
So these two reasons contribute to each other and the neglection of the velocity is justified.
user2554
  • 547
