Consider a cylindrical universe. Because it is closed (at least in one direction) and non-expanding, I can figure out the distance, say, from the Earth to the same over the full circle of the universe. Now consider I am flying in a relativistic spaceship near the Earth. In this case, if I measure the distance from the ship to the same ship over the full circle in the direction of the flight, this distance would seem to me Lorentz contracted and therefore shorter than the one for the Earth. This way the preferred frame may be chosen as the one with the longest distance over the full circle. This logic is apparently endorsed by some, but does it not violate relativity? For example, if the space is circled only along one dimension, then the curvature is zero and Special Relativity should apply. Should it not?
Asked
Active
Viewed 259 times
If so you wouldn't need a closed universe for your argument, because accoording to that logic it would already be enough to define the prefered reference frame in a way that in this frame the distance between the regular stars and galaxies would be the longest (which happens to be the frame of a comoving observer, who observes no dipole in the cosmic microwave background).
But yes, just like you can chose your frame to be at rest with the cmb in an flat and expanding universe, you also could define your prefered frame by the longest distance to yourself in a nonexpanding closed universe.
Yukterez
- 14,655
