- Why charged particle has to be in motion to define magnetic field?
- Will magnetic force exert any force on a static charge? (as in the static test charge in electric field)
- A line from my book reads-
"If a magnetic monopole (individual magnetic charge) were available, we could define magnetic field B in a similar way as electric field."
What would be similar to magnetic field and electric field if individual magnetic charges actually existed?
- 42,352
- 31
- Because of the answer to 2.
- No. This is what distinguishes a magnetic field from an electric field. In an electric field a charge experiences a force (proportional to its charge), whether it's stationary or moving. In a magnetic field a charge experiences a force only if it's moving.
Why is it useful to make the distinction? A simple-minded answer is that a magnet exerts a force on a charge moving near it (making it change its direction of motion) but not on a stationary charge. The dome of a working Van Der Graaff generator exerts forces on both stationary and moving charges.
- Up until sixty years or so ago, most physicists did define magnetic field strength in terms of the forces on a magnetic pole. The pole was sometimes approximately realised in practice as one pole of a ball-ended magnet. [The magnetic field from a single pole obeys an inverse square law, like an electric field from a point charge (but, if you're using a ball-ended magnet – and there's no alternative in practice! – the law doesn't hold inside the magnet itself!)]
Unlike a moving charge, a magnetic monopole would experience a velocity-independent force in the same direction as the magnetic field it is in, just as a charge experiences a velocity-independent force in the same direction as the electric field it is in. That's the similarity of definition that would be made possible if magnetic monopoles existed.
- 2,415
- 1
- 5
- 32
- 37,325
1 - A particle doesn't have to be in motion to define a magnetic field. A stationary particle will just create a null magnetic field (see Biot-Savart law).
2 - No. See Lorentz's force $\vec{F} = q\vec{v}\times\vec{B} = 0$ if $v=0$.
3 - A magnetic monopole would just behave as a source of magnetic fields. In this sense, two stationary magnetic monopoles would exert a force on each other just as two electric charges exert a force on each other (just the force constant would be different). Furthermore, a moving magnetic charge would generate an electric field, just as a moving electric charge generates a magnetic field.
- 2,415
- 1
- 5
- 32
