A Helmholtz coil is an arrangement of two circular coils that produces a magnetic field in the center which is locally uniform in direction and magnitude, or at least nearly so. The configuration is optimal when the radius of each coil is equal to the separation between coils.
If the coils were replaced with massive rings, would this also produce a locally uniform gravitational field in both direction and magnitude? Or would a different diameter to separation be better?
Is there a well-recognized name for this configuration of masses?
uhoh
  • 6,089
The charge moving in a circle produces a magnetic dipole, and it is the proximity of the two magnetic dipoles that produces an approximately constant magnetic field in between the two coils.
However a ring of matter does not produce a gravitational dipole, unsurprisingly since there is no such thing as a negative mass so the analogous gravitational dipole doesn't exist. Indeed at the point exactly between the two rings of matter the gravitational field would be zero since the gravitational attractions to the two rings would be equal and opposite.
The electromagnetic analogy would be to consider the electric field created by two charged rings. The geometry of this field would be the same the same as the geometry of the gravitational field created by two massive rings.
John Rennie
  • 367,598
Fields scale as $M/r^2$, so scaling a structure's dimensions up by $\alpha$ and decreasing its mass density by $\alpha$ leaves the field unchanged. So the field at the center of a cylinder whose diameter increases linearly along its length (I initially incorrectly suggested exponential) and whose mass-density is decreasing inversely with length will have the same constant non-zero field everywhere along its length.
A linear change with length means, of course, that its a simple cone. We can expand the angle at the vertex until the cone becomes a sphere. So if you take a planet with a hole through the middle that happens to have a mass density inversely proportional to radius, then the field will be constant and reverse sign at the center. In fact, the hole doesn't have to go through the middle. The field everywhere has a constant magnitude, only its angle changes. Actually I read somewhere that the earth's density has a slight tendency towards a 1/r dependence and the field in the first 1000 miles or so doesn't change much, but I don't have a reference.
If we talk about a conical shell then the area mass density has to be constant for the constant field scaling to apply. So next time you eat an ice cream cone please be aware that its gravitational field along its axis is roughly constant.
Thinking of a simple structure more analagous to the Helmholz configuration, the field along the axis of a ring radius R goes as $GMx/(R^2+x^2)^{3/2}$. If we place the point mass, $m$, on the axis at distance, $d$, from the ring, the total field is $GMx/(R^2+x^2)^{3/2} + Gm/(x-d)^2$. We can now choose $m$ and $d$ and a position $p$ to set the first, second, and third derivatives to zero. I had to solve this numerically. The answer comes out to be m/M = 1.75620, d/R = -1.41456, p/R = 0.202622. The resulting field is 0.862275*GM/R^2
plot of normalized field vs. normalized position
Roger Wood
  • 2,423
