The time derivative of acceleration (m/s²) is jerk (m/s³).
I know that when you push on an object, there cannot be true instantaneous acceleration, which leads to infinite jerk, because the object must compress ever so slightly before it starts to move.
However, what if an object is suspended in a vacuum using an electromagnet? When the power is cut, would it release all attractive force instantaneously in exactly no time? Would the jerk be infinite at the moment of the start of free fall? Note: Acceleration will be in standard gravity.
Also, what if the object is hung by a string, and the string snaps due to too much tension (for example, object too heavy)? Will the jerk be infinite?
Also, how about snap (m/s⁴) and crackle (m/s5)?
