-3
Suppose there are 2 observers each with a watch, both show exactly the same time.
Suppose observer A stands on earth (which may be considered an inertial frame of reference) and observer B sits in a spaceship with speed as much as 100,000,000 m/s. When both will later meet on earth again, if the proper time was 100 s, then putting the values in the time dilation equation, the new time will be 106 s i.e. a difference of 6 seconds in the watches.
For observer A, the watch of observer B is the event and it should be showing 100 seconds while his own watch shows 106 seconds has passed. But for observer B, the watch of observer A is the event and he should see that it is the watch of observer A which is showing 100 seconds while his own watch shows 106 seconds.
Following the time dilation principle both observers should see that it is the other's watch which is showing the effect of time dilation and is 6 seconds behind (because the time for the event had slowed down or dilated). But isn't this practically impossible that each one observes a different time in their own and the other's watch? What will happen in actuality?
Kyle Kanos
  • 29,127
L..
  • 45
How do they communicate with each other? As the communication is non-instantaneous they must either send a signal to one another (which takes time!) or one must return back to the other, requiring acceleration.
