Should a black hole be considered two-dimensional or three-dimensional?
It means that a black hole doesn't occupy space, but interacts with it. Or it actually occupies space, and still interacts with it?
The event horizon is a three-dimensional surface. It's obtained by restricting the Schwarzschild $r$ coordinate to to a single value, which takes four-dimensional spacetime and reduces its dimensionality by one. For the same reasons the surface of a basketball is a three-dimensional surface. In the case of the basketball's surface, there are two spacelike dimensions, and the basketball also has extent in time, so that makes a total of three dimensions.
The dimensionality of the singularity is not well defined. GR doesn't describe a singularity as a point or set of points. It describes it as something that is simply missing from spacetime. The missing part doesn't have a well-defined geometry or topology, so we can't define how many dimensions there are. There have been attempts to construct such a definition. These attempts are referred to as "boundary constructions." So far, nobody has come up with a satisfactory boundary construction that everybody agrees is correct in all cases.
-2
If you consider the even horizon of the black hole as where the black hole ends, then it is certainly a three-dimensional object.
If you consider just the singularity at its center you may get away with thinking of it as a zero-dimentional object, since you would think of it as a point. Of course, the story gets more complicated by the fact that you cannot visit this point and then go back, since once you are inside of the event horizon, you will keep moving towards the black hole singularity. In that sense the singularity is not at a point in space but rather a point in time. No matter what direction your travel, you will always end up there.....
You also mention "two-dimensional" in the question as well. I guess you are thinking of the holographic principle as the fast that the entropy of the black hole only grows as the area of the black hole and note the volume of the black hole. In that sense calling a black hole two-dimensional is the most accurate, since the information contained in the black hole scales as a two-dimensional object.
Finally: The black hole will eventually evaporate due to Hawking radiation.
Kenneth Kho
  • 155
