Without calculating it, it isn't obvious to me that if you take Planck's Law for the spectral radiance as a function of temperature of a black body and shift all the frequencies by the same factor, you will get a curve that is also a blackbody curve, but at lower temperature.
But because the blackbody curve is entropy maximizing, it seems there might be some sort of thermodynamic argument for this, e.g. a thought experiment which shows that if the redshifted spectrum were not a blackbody spectrum, it would be possible to build a perpetual motion machine with some sort of blackbody oscillating on a spring that sees different $z$-shifts at different times.
Is there such an argument, or something roughly similar?
