This is not a new argument but I wanted to see what sort of counter-arguments are produced here. According to Wikipedia, the Sun's surface gravity is 28.02 times earth surface gravity, and the moon's surface gravity is 0.1654 times earth surface gravity.
Assumption set 1:
The angular diameter or apparent diameter of an object is:
2*arcsin(diameter-actual/2/distance to object)
For the sun and moon, these are very nearly the same (during an eclipse, the sun and moon appear to be almost exactly the same size), so
diameter-sun/2/distance to sun = diameter-moon/2/distance to moon
or
distance to sun / distance to moon = diameter-sun / diameter-moon
Assumption set 2:
SurfaceGravitySun = GravitationalParameterSun/HalfSunsDiameterSquared
SurfaceGravityMoon = GravitationalParameterMoon/HalfMoonsDiameterSquared
SunsGravityForceAtEarth = GravitationalParameterSun/DistanceToSunSquared
MoonsGravityForceAtEarth = GravitationalParameterMoon/DistanceToMoonSquared
where the GravatationalParameter is the Gravitational Constant multiplied by the mass of the Sun or Moon.
So...
SurfaceGravitySun * HalfSunsDiameterSquared = DistanceToSunSquared * SunsGravityForceAtEarth
and
SurfaceGravityMoon * HalfMoonsDiameterSquared = DistanceToMoonSquared * MoonsGravityForceAtEarth
If we divide the equations we get equation 1:
SurfaceGravitySun * HalfSunsDiameterSquared / SurfaceGravityMoon / HalfMoonsDiameterSquared =
DistanceToSunSquared*SunsGravityForceAtEarth / DistanceToMoonSquared / MoonsGravityForceAtEarth
Going back to Assumption set 1,
DistanceToSun/DistanceToMoon = DiamenterSun/DiameterMoon
which we can easily make into equation 2:
HalfDistanceToSunSquared/HalfDistanceToMoonSquared = HalfSunsDiameterSquared/HalfMoonsDiameterSquared
So now substitution of equation 2 into 1 yields...
SurfaceGravitySun * HalfDistanceToSunSquared / SurfaceGravityMoon / HalfDistanceToMoonSquared =
DistanceToSunSquared * SunsGravityForceAtEarth / DistanceToMoonSquared / MoonsGravityForceAtEarth
Removing and cancelling the Half's on the left side means the distance terms completely cancel, leaving equation 3:
SurfaceGravitySun / SurfaceGravityMoon = SunsGravityForceAtEarth / MoonsGravityForceAtEarth
Assumption set 3:
Lunar tides are stronger than solar tides, therefore SunsGravityForceAtEarth < MoonsGravityForce at earth.
Therefore
SurfaceGravityMoon > SurfaceGravitySun
Something's not right here, obviously. So what's wrong with the argument?
