11
I understand that light entering a parallel block of glass at a non-90 degree angle will cause dispersion of colours within the block but that these will be refracted by the same degree upon exit so there will be no overall dispersion and will appear white. But in that case, why don't concave (or convex) lenses disperse?
Additionally, with a block of parallel glass, if it were sufficiently thick and wide, although different frequencies would eventually "catch up" to each other and merge upon exit, this would occur only after a distance equal to the distance they were dispersed inside the glass right? So the human eye, if positioned close enough to the exit side of the glass, would be able to see a rainbow correct?
M. Santos
  • 121
They do. It's called chromatic aberration - each different frequency has a slightly different focus point, blurring the image by different amounts for the different colors. Modern lenses of high quality have multiple elements added specifically to address the issue of chromatic aberration.
What happens with flat glass can be explained by thinking of it in terms of the wave fronts instead of the ray paths, because that is closer to the physical optics. For a person looking directly through the glass, it messes up the phase relationship between waves of a different color, but our eyes aren't sensitive to that, anyway. A spherical wave front on one side will be spherical on the other, for all colors (same for flat). All of the spherical wave fronts that share a center on one side of the glass will have a center that is on the same line on the other side. Because of this, if you look through the glass at an angle you'll observe a small chromatic aberration.
Sean E. Lake
  • 22,927
Sean E. Lake's answer is right: convex lenses disperse light like prisms and that effect is known as chromatic aberration - which is easily noticeably by zooming in in the corners of photographs taken with cheap cameras.
I would add to his answer the reasons why usual convex lenses disperse light much less than a prisma does. For example, it's difficult to project an spectrum using a pair of common eyeglasses, a magnifier or even a photography objective.
The first reason is that lenses are usually thin, and therefore their sides are nearly parallel - at least compared with a prism. Dispersion is very related to angle between faces, and lens faces are just a few degrees apart while in a prism they could be at 60ยบ.
The second reason doesn't hold for simple lenses (like eyeglasses or magnifiers) but holds for more complex systems equivalent to a convex lens (like photography objectives): lenses are combined in a way that most of their chromatic aberration get cancelled.
Pere
  • 2,249
