I'm reading in several places (e.g., here), that
the current density is supposed to be in the form $\mathbf{j}=j(r, z) \exp(i\omega t) \,\mathbf{e}_\varphi, [...]$
This implies that the current density has complex values, while I had been under the impression that it, as an observable quantity (the electric current per unit area), is always real-valued.
How to consolidate the two views?
Nico Schlömer
  • 343
  • 15
The current is real-valued like electromagnetic fields. The complex formalism is largely used in electromagnetism when you have to face oscillating quantities because it is easier to handle that cosines / sines.
You can do calculation using the complex notation and then take the real part of the expression to come back to the physical quantities.
In your case the current is $\mathbf{j}=\Re( j(r, z) \exp(i\omega t))\,\mathbf{e}_\varphi$. Taking real part of a complex quantity in electromagnetism it is usually implicit.
299792458
  • 3,214
