In an effort to understand more about the first law I was wondering about the potential energy term and how it would influence the gas inside the box I made this question and tried to answer it.
I will assume that the air follows the ideal gas law, there is no air resistance and the box stops moving immediately when it reaches the rigid ground.
The first law: $$ 0 = \Delta PE + \Delta U\\ gH = c_v (T' - T)\\ T' = gH/c_v + T $$
would this be correct or missing something? (i.e. invalid assumptions..)
I am also wondering if the energy is fully transferred to the ground instead..
$Energy\space of\space the\space system\space (E) = Internal\space energy\space (U) + PE_{system} + KE_{system}$,
$\Delta E =\Delta U+\Delta{PE} + \Delta{KE}$,
The condition for $\Delta E =\Delta{U}$ is $\Delta{PE}=\Delta{KE}=0$.
The first law of thermodynamics gives us the relation between the change in energy of the system and heat and work.
$\Delta E + PdV=Q$,
$\Delta U+\Delta {PE} + PdV=Q$ $\tag1$
In your question, $\Delta {PE}=-mgh$ and $PdV=0 $ $(as\space dV=0)$.
Your equation is correct.
Check this out : What is the meaning of internal Energy?
Mitchell
  • 4,937
  • 25
  • 38
-1
Exactly, $dU=\delta Q -\delta W$, and here $\delta W=mgh$ and $\delta Q=0$. You can run some numbers to see that the value is very small for realistic settings.
