I want to understand what is wrong with the following argument:
in a topologically compact spacetime, a closed 3D boundary separates the spacetime in two connected components, because of this continuous symmetry, either one of the two things must happen
1) the stokes theorem is not valid
2) the integral of the derivative of any form field in each connected component must be equal in magnitude and opposite in sign, since both must be equal to the surface integral of the form field, and they must be all identical to zero at all times
In layman terms, if the space is compact, a gauss surface does not separate the space neatly in a interior region and an external region, rather, both connected components are topologically equivalent, so one is led to the startling conclusion that the validity of the stokes theorem (which naively looks of a local, differential nature) depends for its validity on the asymptotic boundary conditions of the space
user56771
  • 873
The answer is just option 2--- the integral on the two sides are necessarily equal in a compact orientable space. The condition of orientability cannot be omitted, see this example: Dirac string on (periodic) compact space
