How to prove the work done by an ideal gas with constant heat capacities during a quasi-static adiabatic expansion is equal to W=-C(Ti-Tf).
I know we can use 1st law thermodynamic, Q=U-W where, Q = Heat, U = Internal Energy, W = Work
However, my derivation/prove leads to wrong and mess-up equation.
W = ΔU
W = -PdV
W = -(K/V^Y)*dV
W = -K∫(1/V^Y)*dV
W = -K[V^(1-Y)/(1-Y)]*∫dV
W = -(K/(1-Y))[Vf^(1-Y) - Vi^(1-Y)]
W = -(K/(1-Y))[Vf^(-Y)*Vf - Vi^(-Y)*Vi]
W = -(1/(1-Y))[((Vf*K)/(Vf^Y)) - ((Vi*K)/(Vi^Y))]
Then i confuse.
MrAZ
  • 155
The derivation to get the term $PV^{\gamma}=constant$ for an adiabatic process, uses the heat capacity at constant volume in its initial steps.
$\Delta U=nC_v\Delta T$ $\tag1$
For an adiabatic process $q=0$,
$\Delta U=W$
$nC_v\Delta T=-PdV$ $\tag 2$
Equation $(2)$ is all you need.
One might argue why heat capacity at constant volume is used when there actually a observable change in volume of the system.
The term $\Delta U=nC_v \Delta T$, is independent of the process that the ideal gas goes through, even when $\Delta V \neq 0 $.
In you wish to know more about $\Delta{U}$, check out these links : When is $\Delta U=nC_V \Delta T$ true? and Work done in adiabatic process.
Mitchell
  • 4,937
  • 25
  • 38
