I would like to know what the relationship between bitrate and the width of spectrum that needs to be assigned to an optical channel is; assuming the channel uses an OOK modulation format such as RZ or NRZ.
Context- First of all I would like to start with, I am not a physicist, and so I don't necessarily understand everything involved with this. I am a computer scientist currently studying routing algorithms over fibre optics in the presence of impairments, specifically in flexi-grid networks; and as part of that I need to build a somewhat realistic simulator. I know that the higher the bitrate of a signal the higher the optical bandwidth required to transmit that signal, and that different modulation formats will require more or less optical bandwidth for the same bitrate. However, I am limiting myself to OOK modulation formats, which I have read can go up to 40 Gbps with current technology(correct me if I am wrong).
Question -So what I would like to know is, if I wanted to assign an optical bandwidth (from my spectrum range, in the flexi-grid network) to an OOK transmission of a given bitrate, assuming a noiseless channel, what would the relationship be?
More context - I saw a video on youtube "what is the maximum badwidth" which says the relationship is $\Delta f * \Delta T \approx 1$ is the relationship (where $\Delta f$ is the assigned spectrum width and $\Delta T$ is the pulse duration). I would like to gain some more insight into what is going on (where does it come from, why should it be approximately 1) , and most importantly confirm if I would be correct to use them in the way I am planning to.
Aside from an answer to the question, any insights, suggestions, or criticisms relating to anything written above would be appreciated.
The answer to your question depends on the system's signal to noise ratio. The SNR determines the number of distinguishable "letters" that can be transmitted with each symbol, as I discuss here.
With unsqueezed light states, and with the only noise present being quantum noise, the following rough formula gives you a good idea:
$$\mathcal C = B \, \log_2\left(1 + \sqrt{\frac{P}{B\, h\, \nu_0}}\right)$$
where $C$ is the channel's capacity bits per second, $B$ the bandwidth in symbols per second, $P$ the optical power and $\nu_0$ the channel center frequency. I show how this figure is derived in this discussion of fiber optic bandwidth.
These figures are theoretical maximums over all possible modulation and encoding schemes.
Selene Routley
  • 90,184
  • 198
  • 428
