I know that heat capacity is defined as the amount of energy required to increase the temperature of any given amount of substance by 1 Degree or 1 Kelvin . Since photons also have mass , is it possible that any given photon may have a specific amount of heat capacity ? If yes than how shall I calculate it ?
Heat capacity is a thermodynamic variable, i.e. when talking of particles it can be defined within statistical thermodynamics, but not for individual particles.
Since photons also have mass,
A photon is an elementary particle with zero mass, spin and energy $h\nu$.
Is it possible that any given photon may have a specific amount of heat capacity ?
No, it is impossible. In general individual particles cannot have thermodynamic properties which are statistical by construction. More so zero mass particles such as the photon.
- 137,480
- 236,935
Heat capacity is defined as the amount the energy of a system changes as the temperature is changed while the system remains at constant volume, $$C_V\equiv\left(\frac{\partial E}{\partial T}\right)_V.$$
Photons are massless bosons, which means their density of states is given by the Bose-Einstein distribution, $$n(p) = g[e^{E(p)/T}-1]^{-1}$$ in $\hbar=c=k_B=1$ natural units and where $g=2$ is the degeneracy of the particles, in this case 2 for the two polarizations possible for photons. Therefore the energy of a gas of photons at temperature $T$ is, as $E=p$ for massless particles, $$E=\int d^3x d^3p\,E(p) n(p)=4\pi g V \int_0^\infty p^2 dp\frac{p}{e^{p/T}-1} = 4\pi g V \frac{\pi^4T^4}{15}.$$
Therefore the heat capacity for a gas of photons is $$C_V=\frac{8\pi^5VT^3}{15}.$$
- 1,149
