The masses of electron, proton and neutron (in SI units) are (approx.):
\begin{equation} m_e=\text{electron mass}=9.109\times 10^{-31}\ \text{kg} \end{equation} \begin{equation} m_p=\text{proton mass}=1.673\times 10^{-27}\ \text{kg} \end{equation} \begin{equation} m_n=\text{neutron mass}=1.675\times 10^{-27}\ \text{kg} \end{equation}
The unified atomic mass unit ($u$) is defined as one twelfth of the mass of Carbon-12.
\begin{equation} u=1.661\times 10^{-27}\ \text{kg} \end{equation}
Now, Carbon-12 contains 6 electrons, 6 protons and 6 neutrons, so the mass of this isotope should be:
\begin{equation} m=\text{Carbon-12 mass}=6\times(m_e + m_p + m_n)=6\times 3.3489 \times 10^{-27}\ \text{kg} \end{equation}
Then:
\begin{equation} \frac{m}{12}=0.5\times 3.3489 \times 10^{-27}\ \text{kg}=1.674 \times 10^{-27}\ \text{kg} \end{equation}
But this value is different from the value of $u$. Shouldn't $m/12$ be equal to $u$?
slaaidenn
  • 584
No.
The difference in that calculation is due to the nuclear binding energy of the carbon nucleus, which affects the mass via the good old $E=mc^2$. In short, pretty much all nuclei are a bit lighter than their constituent parts would be, which reflects the fact that you would need to put in energy (a.k.a. mass) to split them up into said constituent parts.
Emilio Pisanty
  • 137,480
