Suposse we have a charged particle placed in some region with an uniform electric field. It's clear that a force $$\vec F_e =q\vec E $$ will appear on the particle due to Lorentz force. However, the particle will radiate with a power of $$P=q^2a^2/6\pi\epsilon_0c^3,$$ where $a$ is the magnitude of the acceleration, according to Larmor formula for power radiated. For energy conservation, a recoil force should appear on the particle. So my question is, the acceleration of the particle will be $$\vec a=q\vec E/m$$ or will it be lower?
Asked
Active
Viewed 610 times
If the charged particle is composed of smaller charged elements, the Lorentz-Abraham force is a validly derived approximate expression of internal force the charged particle will experience. However, magnitude of this force is so small that its effect on the motion of the charged particle has so far been unmeasurable.
If the particle is a point, so it is not made of smaller elements, the Poynting theorem cannot be interpreted as work-energy theorem and the usual derivations of the Lorentz-Abraham force fail. Such particle should not experience any internal force.
Ján Lalinský
- 44,745
