We know for a fact that for any medium with permittivity $\epsilon$ and permeability $\mu$, the propagation speed of electromagnetic waves is given by
$$v = \frac{1}{\sqrt{\mu\epsilon}}$$
We also know that the speed a wave travels at can be calculated as
$$v = \frac{\omega}{\beta}$$
For a lossless transmission line, the constant of propagation is $\beta=\sqrt{\omega^2LC}$, so the velocity can be expressed as
$$v = \frac{1}{\sqrt{LC}}$$
And this is where my doubt arose. The two equations I wrote above for propagation speed have to be equal. Ergo
$$ \frac{1}{\sqrt{\mu\epsilon}}= \frac{1}{\sqrt{LC}}\implies LC = \mu\epsilon$$
I find that relationship rather weird. I mean, it's not that hard to believe, because the inductance depends on $\mu$ and the capacitance on $\epsilon$. However, I don't understand why that equality would hold no matter what the geometry of the problem is or any other factor.
Is the reasoning correct? Does that equality hold? If the answer is yes, then why is it independent of the geometry?
Cross
  • 3,360
Tendero
  • 1,213
I think you may have forgotten that although $L$ and $C$ here are 'lumped' parameters that facilitate the abstract model of the transmission line (idealised by $LC$ elements per unit length), these modelling parameters must eventually be linked to physical reality, and therefore must necessarily include geometry.
Indeed, finding the relation between $L,C$ (and also $R,G$ in the lossy case) and the physical geometry of the line's (or waveguide's) cross section is a known classical problem and is the premise of microwave engineering and electromagnetic field theory for guided waves (see for example, Pozar, p.51 onwards, or Collin's books here and here), which are mainly applied electrodynamics.
Specifically, here are the general equations that link these parameters with geometry (arbitrary cross-section of a typical line that is longitudinally uniform) [see Pozar, p. 52 and figure 2.2]:
$$ L=\frac{\mu}{|I_{0}|^{2}}\int_{S} \bar{H}\cdot\bar{H}^{*} ds \ \ \ \ \ \ \ \text{H/m}$$
$$ C=\frac{\epsilon'}{|V_{0}|^{2}}\int_{S} \bar{E}\cdot\bar{E}^{*} ds \ \ \ \ \ \ \ \text{F/m}$$
$$ R=\frac{R_{s}}{|I_{0}|^{2}}\int_{C{1}+C_{2}} \bar{H}\cdot\bar{H}^{*} dl \ \ \ \ \ \ \ \Omega\text{/m}$$
$$ G=\frac{\omega\epsilon''}{|V_{0}|^{2}}\int_{S} \bar{E}\cdot\bar{E}^{*} ds \ \ \ \ \ \ \ \text{S/m}$$
where $S$ is the surface area of the cross section (arbitrary shape), $C_{1,2}$ are the inner and outer contours of that cross section, with $ds, dl$ being the respective surface and distance elements, $R_{s}$ being the surface resistance of any conductor (typically lining the outer/inner contours cylinders) with the dielectric matrial having imperfect (complex) permittivity $\epsilon=\epsilon'-i\epsilon''$, and $I_{0}, V_{0}$ are the (arbitrary) amplitudes of current or voltage of the travelling wave on the line.
As you can see from the integration over the contours and surfaces, and including the $E$ and $H$ fields within the structure, such calculations will inevitably depend on the geometry.
As a famous example, a coaxial line that has outer conductor of radius $b$, inner conductor radius $a$, with a dielectric sandwiched between these two conductive cylinders, with surface resistance $R_{s}$ for the conductor, will have (after performing the integrations above):
$$ L = \frac{\mu}{(2\pi)^{2}}\int^{2\pi}_{\phi=0}\int^{b}_{r=a}\frac{rdrd\phi}{r^{2}}=\frac{\mu}{2\pi}\ln(b/a)\ \ \ \ \text{H/m}$$
$$ C = \frac{\epsilon'}{(\ln b/a)^{2}}\int^{2\pi}_{\phi=0}\int^{b}_{r=a}\frac{rdrd\phi}{r^{2}}=\frac{2\pi\epsilon'}{\ln(b/a)}\ \ \ \ \text{F/m}$$
$$ G = \frac{\omega\epsilon''}{(\ln b/a)^{2}}\int^{2\pi}_{\phi=0}\int^{b}_{r=a}\frac{rdrd\phi}{r^{2}}=\frac{2\pi\omega\epsilon''}{\ln(b/a)}\ \ \ \ \text{S/m}$$
$$ R = \frac{R_{s}}{(2\pi)^{2}}\left[\int^{2\pi}_{\phi=0}\frac{ad\phi}{a^{2}}+\int^{2\pi}_{\phi=0}\frac{bd\phi}{b^{2}}\right]=\frac{R_{s}}{2\pi}\left(\frac{1}{a}+\frac{1}{b} \right)\ \ \ \ \Omega\text{/m}$$
As you can see, the result clearly depend on geomerty.
Your derived equation $LC = \mu\epsilon$ in order to hold, $L$ and $C$ characteristic values of the transmission line must be expressed as per-unit length. Link.
So the equality is not geometry independent.
Markoul11
  • 4,572
