This is a curious question, since stars, black holes, white dwarfs, quasars etc do accrete matter and do find a way to transfer orbital angular momentum outwards whilst transferring mass inwards and that process does occur because of viscosity, but the angular momentum is not transported by radiation as you suggest.
The energy radiated comes about because of the inward mass flow, not vice-versa. The amount of angular momentum lost in the form of light is totally negligible. To carry angular momentum the light would need to be circularly polarised. Circular polarisation of light from sources such as quasars is quite limited (e.g. see Hutsmekers 2010) and even if the light were 100% polarised it could only carry $\hbar$ of angular momentum per photon. Thus, the angular momentum per energy unit would be $\omega^{-1}$, where $\omega$ is the frequency of the light, compared to the angular momentum per energy unit of a mass in a circular orbit of $2\Omega^{-1}$ (e.g. see here), where $\Omega$ is the orbital frequency. Since $\omega \gg \Omega$, then the angular momentum of the light is irrelevant - a body in orbit that loses energy just by emitting light loses a negligible amount of angular momentum and therefore cannot move inwards by this mechanism alone. To put it another way, a hot body in orbit that radiates away its thermal energy just turns into a cold body in the same orbit.
To fall into a lower orbit then a torque needs to be exerted because the specific angular momentum of an object in orbit is $\propto r^{1/2}$. Angular momentum is transferred outwards by torques associated with viscosity - at the microscopic level this is still poorly understood. Material in closer orbits moves faster than material further out. Turbulence or magneto-rotational instabilities may be capable of supplying the required viscosity. Angular momentum can also be lost from the system as a whole via winds from the disc surface or rotating jets propelled along the rotation axis; but not by electromagnetic radiation.
