Consider two electrons approaching each other at rather fast speeds, maybe even coming close to colliding. Does gravity play any role in this event? If so, how much influence does it have? Do we need gravity in charged particles?
Gravitation is a negligible effect unless you have a large number of particles and a very small percentage of net charge.
For two protons, the electromagnetic force is $10^{36}$ times stronger than their gravitational force. But if you have a small object made up of protons and neutrons and electrons, with a total of about $10^{36}$ atoms and just one more proton than electrons, then the forces are equal. For planetary, stellar, and galactic sizes the electromagnetic force can be ignored compared to gravity, except when you have localized overcharges like around solar flares.
For atoms and molecular effects, or even electrical circuits, gravitation can just be ignored
See relative strengths of the elementary 4 forces at Wikipedia page on fundamental interaction.
For two individual electrons, the electric force will be much more powerful at all points.
For example, suppose they are 1 meter apart, the gravitational force on each electron will be (the fact that they are moving does not change the force):
$$F_G = \frac{Gm_e^2}{r^2} = \frac{6.674\times 10^{-11}\times 8.297\times 10^{-61}}{1^2} = 5.538\times 10^{-71} \:\mathrm N$$
The electric force will be:
$$F_E = \frac{kq_e^2}{r^2} = \frac{8.988 \times 10 ^ 9 \times 2.566 \times 10 ^ {-38}}{1^2} = 2.306 \times 10 ^ {-28}\:\mathrm N$$
We can see that the electric force is several magnitudes higher than the gravitational force.
- 137,480
- 221
Although eletromagnetic force tends to be higher in magnitude then gravitational forces, the presence of negative and positive charges neutralizes the effect of this force... Gravitaional force on other hand, is additive and increases propotionaly in magnitude with mass.
Technically: yes (any mass attracts any other mass)
How much: Negligible (gravity is ~$10^{36}$ smaller then EM)
Needed: not for calculations (of your electron-electron collision)
But beware that the question of "is it needed" is quite "wrong": We need information to make accurate calculations or don't need them, we need sunlight to grow plants but:
- electrons have mass (observation)
- any mass attracts other mass through gravity (observation)
Gravity acts between two electrons. The question of whether they "need" to be attracted cannot be asked here, it's like asking whether you need to fall down if you jump of a building... well you will. Ask the designer of the universe (whoever it may be) why he needed the electrons to "have mass";)
For further informations, read through the other answers, they are good as well.
- 882
For electrons, the gravitational force is much smaller than the electric forces. To get an idea about how small, let's math. $$F_g = \frac{Gm_1m_2}{r^2}\, , \, F_e = \frac{kq_1q_2}{r^2}\\ \frac{F_g}{F_e} = \frac{Gm_1m_2}{kq_1q_2}$$
Notice, the distance separating the electrons does not matter when comparing the forces. All of these constants are pretty easy to find, so the gravitational force is $2.4\times 10^{-43}$ the size of the electric force. Since we know nothing in the universe to within two parts in $10^{43}$, we may safely ignore gravity.
You mentioned that the electrons were on a collision course. Moving charges, especially fast moving charges, create magnetic fields, and those would be important in your calculations.
- 2,222
