As I understand it, the classical source-free electric, $\mathbf{E}$ and magnetic, $\mathbf{B}$ wave equations are solved by solutions for the electric and magnetic fields of the following form: $$\mathbf{E}=\mathbf{E}_{0}e^{i (\mathbf{k}\cdot\mathbf{x}-\omega t)}$$ $$\mathbf{B}=\mathbf{B}_{0}e^{i (\mathbf{k}\cdot\mathbf{x}-\omega t)}$$ Naively counting the degrees of freedom (dof) at this point it would appear that the electromagnetic field has 6 dof.
However, is it correct that Maxwell's equations provide 4 constraints: $$\mathbf{k}\cdot\mathbf{E}_{0}=0 \\ \mathbf{k}\cdot\mathbf{B}_{0}=0$$ $$\mathbf{E}_{0}=-\frac{1}{\sqrt{\mu_{0}\varepsilon_{0}}}\mathbf{k}\times\mathbf{B}_{0}$$ and $$\mathbf{B}_{0}=\sqrt{\mu_{0}\varepsilon_{0}}\mathbf{k}\times\mathbf{E}_{0}$$
Thus reducing the number of physical dof to 2?!
If the above is correct what do these remaining dof correspond to? Are they simply the two possible polarisation (unit) vectors $\mathbf{\epsilon}_{1}$, $\mathbf{\epsilon}_{2}$ that one can construct such that $$\mathbf{k}\cdot\mathbf{\epsilon}_{1}=\mathbf{k}\cdot\mathbf{\epsilon}_{2}=0$$ and $$\mathbf{k}\times\mathbf{\epsilon}_{1}=\mathbf{\epsilon}_{2}\\ \mathbf{k}\times\mathbf{\epsilon}_{2}=-\mathbf{\epsilon}_{1}$$ and hence $\lbrace\mathbf{k},\;\mathbf{\epsilon}_{1},\;\mathbf{\epsilon}_{2}\rbrace$ form an orthornormal basis, such that the general solutions for $\mathbf{E}$ and $\mathbf{B}$ are linear combinations of $\mathbf{\epsilon}_{1}$ and $\mathbf{\epsilon}_{2}$?!
user35305
  • 3,327
The constraint you're missing is the Faraday law of induction. For a pure plane-wave mode, if you know the amplitude of the electric field, the Faraday law completely determines the magnetic field. Thus, you have two degrees of freedom in the electric field and none in the magnetic field.
Emilio Pisanty
  • 137,480
