-1
I was reading about torque and pseudo forces and my book says that the torque about centre of mass for a Pseudo/Fictious force is zero.
I cant really get that as it is non-intuitive for me .
Can someone explain it in a simple manner.
Any help is appreciated
While we sometimes think of things as pseudo-forces, they're really better thought of as accelerations (note: I don't have to call them pseudo-accelerations). The pseudo-forces are all results of using non-inertial frames*, which means they have an acceleration term which accounts for the non-inertial effects. For example, the "centrifugal force" in a rotating frame is more accurately a "centrifugal acceleration of $\frac{v^2}{r}$. This term can be derived directly from the change of frame from inertial to rotating, using calculus.
Sometimes it is convenient to choose to think of this effect as a force rather than thinking of it as an acceleration. If we multiply that acceleration by the mass of the object and treat it as a force, we get the exact same equations (it's simple algebra to convert one to the other). This is how we get a pseudoforce.
Now, to answer your question, this effect was best thought of as an acceleration the entire time. This acceleration does not cause the object to rotate about its center of mass. This is why the pseudoforces must always act on the center of mass. If the pseudoforce were to act on any other point, then the pseudoforce would cause a torque. If it caused a torque, it would no longer be a drop-in replacement for the acceleration term.
So in a sense, it's sort of backwards logic. Pseudoforces act on the center of mass because they are a mathematical construct designed to replace another more fundamental effect, and acting on the center of mass is the only way to have a force accomplish this goal.
* All things that I have heard called "pseudoforces" fit this description. If you come across one that does not, we can address it separately.
Cort Ammon
  • 53,814
  • 103
  • 176
