Could the requirement of a dark matter for the missing mass in the universe simply be explained by objects having high relativistic mass change with respect to other objects?
If this is not the case, how is it explained mathematically?
m_power
  • 111
This is the typical rotational curve of a galaxy:
rotcurvegal
Rotation curve of a typical spiral galaxy: predicted (A) and observed (B). Dark matter can explain the 'flat' appearance of the velocity curve out to a large radius.
The red curve is what the luminous mass shows, the blue is what is expected if the luminous mass were the only mass in the system. To make the two curves agree one has to assume a lot of non luminous(dark) matter .
The arms of spiral galaxies rotate around the galactic centre. The luminous mass density of a spiral galaxy decreases as one goes from the centre to the outskirts. If luminous mass were all the matter, then we can model the galaxy as a point mass in the centre and test masses orbiting around it (similar to the solar system). From Kepler's Second Law, we expect that the rotation velocities will decrease with distance from the centre. This is not observed. Instead, the galaxy rotation curve remains flat as distant from the centre as the data is available.
In this link(page2) one gets an estimate of the scale of speeds, the maximum is around 150 km/sec. The velocity of light is 300.000km/second so the motions are non relativistic, newtonian mechanics should be adequate in explaining orbits. Thus the need for dark matter arose.
anna v
  • 236,935
No. First of all, relativistic mass is an outdated concept that is no longer used in modern physics. In modern usage, the mass of an object is invariant, that is, it is the same in every reference frame regardless of how fast it is moving with respect to that frame. It is just the energy of the object that changes as the object increases in speed. General Relativity describes how gravity behaves given the energy of an object. However, unless the object is moving very close to the speed of light, the energy of the object is approximately equivalent to just the mass of the object (times the speed of light squared). This is the case for stars moving around the center of a galaxy, which is what first allowed us to know that dark matter is present. Accounting for the additional energy of the stars due to their motion would change the equations only very slightly.
Travis
  • 3,562
