Any force applied to a body creates a torque around some reference point, but if we ignore all other forces (gravity etc.) the body will rotate if and only if the torque is not zero relative to the centre of mass? How can we prove that? Why is it the centre of mass and not some other point?
If the torque around the CoM is zero, I will still be able to find infinitely many other points such that torque around all of them is not zero, but the body won't rotate at all.
sammy gerbil
  • 27,586
You can think of the center of mass as a point around which the mass distribution of the object is more or less the same. So if you kept the object on a weight balance with the tip of the weight balance at this point the object would be perfectly balanced. Now consider a uniform solid sphere, whose center of mass is at the geometric centre. Now roll it, you will see that all the points except the centre seem to move in concentric circles with a common axis, while the centre just moves in a straight line path. Since it has no rotational motion it is the best reference frame to understand the rotational motion of the other particles.
It's just a useful convention. You can always decompose the motion of a rigid body into a translation and a rotation about some point. If you choose the point to be the CM, things are more convenient, e.g. the kinetic energy separates nearly into linear and rotational parts.
For example, one could say that a ball falling down is actually rotating about a very faraway point. It's just not very useful so we don't define "rotating" in this way.
knzhou
  • 107,105
To answer this question first you must consider how is linear and angular momentum defined. (Here point C designates the center of mass).
  1. Linear momentum is the product of the scalar mass with the linear velocity of a rigid body at the center of mass $$\mathbf{p} = m \mathbf{v}_C$$
  2. Angualar momentum at the center of mass is defined as the product of the mass moment of inertia tensor at the center of mass and the rotational velocity vector $$\mathbf{L}_C = \mathrm{I}_C \boldsymbol{\omega}$$
The reason for this distinction is the linear momentum describes the motion of the center of mass and angular momentum the motion about the center of mass. This separation comes naturally out of the equations when summing up the movement of all the particles on a rigid body.
Once you have accepted the above definitions you find the following:
  1. Net force equals the time derivative of linear momentum $$\sum \mathbf{F} = \frac{{\rm d}}{{\rm d}t} \mathbf{p} = m \frac{{\rm d}}{{\rm d}t} \mathbf{v}_C = m \, \mathbf{a}_C $$
  2. Net torque about the center of mass is the time derivative of angular momentum about the center of mass $$ \sum \boldsymbol{\tau} = \frac{{\rm d}}{{\rm d}t} \mathbf{L}_C = \mathrm{I}_C \left( \frac{{\rm d}}{{\rm d}t} \boldsymbol{\omega} \right) +\left( \frac{{\rm d}}{{\rm d}t} \mathrm{I}_C \right) \boldsymbol{\omega} = \mathrm{I}_C \boldsymbol{\alpha} + \boldsymbol{\omega} \times \mathrm{I}_C \boldsymbol{\omega}$$
So the key here is that a net zero force will cause the center of mass no acceleration (constant velocity = Newton's 1st law) and thus a pure torque will rotate a body about the center of mass. The differentiation of angular momentum retains the disclaimer "about the center of mass" that we establised in the first part of this answer.
The following two statements are true and dual to each other (if one is true, so must the other). They are both a result of the definition of the center of mass.
  • A net pure torque accelerates a rigid body about the center of mass
  • A force through the center of mass accelerates a body with pure translation.
Reference: Derivation of Newton-Euler equations of motion.
John Alexiou
  • 40,139
