I have seen many questions about this, but haven't really found the answer I was looking for.
I was caught by an exercise that said:
Consider two charges: $q$ (a test charge) and $Q$, at $\vec{R}$ and $\vec{r}$, respectively.Assuming that the force $Q$ exerts on $q$ is:
\begin{equation} \vec{F}_{Q \rightarrow q} = \frac{1}{4 \pi \epsilon_0} \frac {q Q}{|\vec{r} - \vec{R}|^{2+\Delta}} \left[ \frac{\vec{r} - \vec{R}}{|\vec{r} - \vec{R}|} \right] \end{equation}
If $\Delta \neq 0$, find the expression that allows you to obtain the photon's mass from $\Delta$.
I have seen some answers using Yukawa's potential, and also an article about it (that my teacher mentioned), but I'd like to know a way (if there is) to obtain the photon's mass without using Yukawa's potential or the Proca equation.
matrp
  • 788
