If an observer passes an electron, in such a way that the observer is accelerating, the observer would see photons because accelerating charges induce electromagnetic waves. But from point of view of the electron or an inertial observer there is no magnetic field nor an acceleration which could 'produce' an electromagnetic wave.
So for the first observer there exists a photon but not for the second observer. How is this possible, are photons relative?
Marijn
  • 3,408
The short answer is yes. When one tries to generalise the theory of quantum fields in Minkowski spacetime to more general spacetimes, one finds that several familiar features of the theory are absent or ambiguous. For instance, it is not generally possible to unambiguously define a vacuum state when studying QFT in a curved spacetime. That is to say, a state which one observer sees as a vacuum, another may see as a thermal bath of particles.
Of course, the spacetime of concern here is just Minkowski spacetime, not a curved spacetime. However, the same problems one faces with QFT in curved spacetime appear also when studying QFT in flat spacetime in some complicated coordinate system, such as accelerating coordinates. Minkowski spacetime in accelerating coordinates is sometimes called Rindler spacetime (although it is the same spacetime), and a lengthy QFT calculation reveals that if our system is in the vacuum state according to an inertial observer, then our accelerating observer will see a background of particles with a perfect black body energy spectrum, with temperature
$$ T = \frac{\hbar A}{2 \pi c k_B} \,,$$
where $A$ is the magnitude of the proper acceleration. This is known as the Unruh effect.
gj255
  • 6,525
To start with, accelerated frames are not inertial frames.
Secondly electrons and photons are elementary particles and are described in a quantum mechanical framework, where everything is particles and interactions of particles.
The blanket term "observer" has to be defined in terms of interactions, in order to be able to write down the mathematics of the system.
For an electron to be accelerated , it has to interact with a field and lose energy emitting a photon, as an example, in this diagram it is the field of another electron with which the upper electron interacts and radiates a photon:
brehsm
Here the lower electron may be considered to start in its rest frame.
The whole diagram is Lorenz invariant, and the only thing that will be changing if one goes to the center of mass of the other electron , is how the energy is supplied to the photons.
In general photons do not disappear in Lorenz transformations, they may increase or decrease in frequency, decrease to the point of huge wavelengths which means that the light beam emergent from zillions such photons may have a wavelength the size of the universe and in the limit represent a static field.
anna v
  • 236,935
