Suppose a bullet were to be fired with a velocity $v$ from the surface at equator. Considering the spin of Earth will it land at the same spot?
I tried to solve this assuming constant acceleration due to gravity.
Since the horizontal velocity of the bullet remains constant at height $h$ the angular velocity will be in (angular velocity at ground is $\omega$ and radius of Earth is $R$) $$ \omega' = \frac{\omega \times R}{(R+h)} $$ Now $\omega'$ can be written as $d\theta/dt$ and $h$ as $v\times t-0.5\times g\times t^2$ so after rearranging we get $$ d\theta = \frac{\omega\times R}{(R+vt-0.5\times g\times t^2)}dt $$ Integrating this wrt to $t$ from $0$ to $2\times v/g$ gives me the angular displacement of the bullet. Angular displacement of ground is $2\times v\times \omega/g $and if we subtract the two and further multiply by $R$ we should get the distance traveled further by the ground.
However after calculating everything I'm getting very high distance. For example, a bullet fired at $1700m/s$ will land $2,340m$ away which seems absurdly wrong. Can anyone point out where my mistake is?
