As a study case, consider the following Lagrangian for a left-handed Weyl field $\chi \in \mathbb{C}^{2}$:
$$\mathcal{L} = \chi^{\dagger} \mathrm{i} \overline{\sigma}^{\rho} \partial_{\rho} \chi$$
where $\overline{\sigma}^{\rho} \equiv (1_{2},-\sigma^{i})$, with $\sigma^{i}$ the standard Pauli matrices. The corresponding Hamiltonian (density) is obtained, as customarily, by a Legendre transformation [with $a$ running, of course, over the two components of $\chi$]:
$$\mathcal{H} = \mathcal{L}\frac{\overleftarrow{\partial }}{\partial \dot{\chi^{a}}}\dot{\chi^{a}}-\mathcal{L} = \mathrm{i} \chi_{a} ^{\dagger }\dot{\chi}^{a}-\mathcal{L},$$
correctly yielding a Hamiltonian containing no time-derivatives: $\mathcal{H} = -\chi^{\dagger} \mathrm{i} \overline{\sigma}^{i} \partial_{i} \chi.$ Now, consider the above Lagrangian augmented by the four-divergence $-\frac{\mathrm{i}}{2}\partial _{\rho }\left( \chi ^{\dagger } \overline{\sigma }^{\rho }\chi \right)$ to bring it on the following explicitly hermitian form:
$$\mathcal{L}'=\frac{\mathrm{i}}{2}\left[ \chi ^{\dagger }\overline{\sigma } ^{\rho }\partial _{\rho }\chi -\left( \partial _{\rho }\chi \right) ^{\dagger }\overline{\sigma }^{\rho }\chi \right];$$
and consider the following ansatz for the associated Hamiltonian:
$$\mathcal{H}' = \mathcal{L}'\frac{\overleftarrow{\partial }}{\partial \dot{\chi }^{a}}\dot{\chi}^{a}+\mathcal{L}'\frac{\overleftarrow{\partial }}{\partial \left( \dot{\chi}^{a}\right) ^{\ast }}\left( \dot{\chi}^{a}\right) ^{\ast }- \mathcal{L}' = \frac{\mathrm{i}}{2}\chi ^{\dagger }\dot{\chi}^{a}-\frac{\mathrm{i}}{2} \chi _{a}\left( \dot{\chi}^{a}\right) ^{\ast }-\mathcal{L}'.$$
Note that the minus sign of the second term comes from passing the derivative through from the right, using anticommutativity. Unlike the former case, here $\mathcal{H}'$ will contain no time-derivatives only if for the second term the relation $\frac{\mathrm{i}}{2} \chi _{a}\left( \dot{\chi}^{a}\right) ^{\ast } = -\frac{\mathrm{i}}{2} \left( \dot{\chi}^{a}\right) ^{\ast } \chi _{a}$ is applied.
At the classical level where the components of $\chi$ are Grassmann-valued, $\chi$ being a spinor field, such a relation is of course fully valid, but I would be more comfortable if the time-derivatives would readily drop out. Is that possible? And if affirmative, then how should the above ansatz for the Legrendre transformation be modified?
  1. The main point is that since e.g. the Lagrangian density ${\cal L}$ should be real, the complex Grassmann-odd Weyl spinors $\chi$ and $\chi^{\dagger}$ are not independent variables. See also this Phys.SE post.
  2. This leads to constraints. When the singular Legendre transformation is performed correctly, the Hamiltonian density ${\cal H}$ does not depend on velocity variables. See also this, this this, this and this related Phys.SE posts.
  3. For a bosonic analogue, see e.g. this Phys.SE post.
