Consider the Lagrangian for a spin 1 massless field with a gauge fixing term: \begin{equation} \mathcal{L}=-\frac{1}{4}F_{\mu\nu}^2-\frac{1}{2\xi}\left(\partial_\mu A^\mu\right)^2-J_\mu A^\mu, \end{equation} where $\xi$ acts as a Lagrange multiplier. Writing down the equation of motion for $A^\mu$ and inverting the corresponding operator leads to the following expression for the photon propagator: \begin{equation} i\Pi^{\mu\nu}(p)=\frac{-i}{p^2+i\epsilon}\left[g^{\mu\nu}-\left(1-\xi\right)\frac{p^\mu p^\nu}{p^2}\right]. \end{equation} Here, each different choice for $\xi$ corresponds to a different gauge.
On the other hand, going back to the Lagrangian, calculating the equation of motion for $\xi$ and excluding the case $\xi\rightarrow\infty$ gives \begin{equation} \partial_\mu A^\mu=0, \end{equation} which is the Lorenz gauge condition.
So it seems that, while I can choose different gauges for the propagator, I am enforcing a specific gauge condition with the equations of motion. How to solve this apparent contradiction? Is it because the fields are not always on shell, i.e. the classical equations of motion are not always satisfied?
Thanks.
gabo_18
  • 61
The parameter $\xi$ is not a Lagrange multiplier, despite the fact that many books insist that it is. It behaves similarly to a Lagrange multiplier, but if it actually were one, then it would enforce $\partial\cdot A\equiv0$ as an operator equation, something we certainly do not want. $\xi$ is not one of the phase space variables of the theory, which means that you cannot write down equations of motion for it - you cannot vary the action with respect to $\xi$. It is a fixed parameter, not a degree of freedom.
The parameter $\epsilon$ doesn't correspond to the choice of a gauge. It is just arbitrary parameter on which our theory is completely independent. Your gauge fixing condition is set by the functional in the front of $\frac{1}{\epsilon}$.
Name YYY
  • 9,071
It is a historical reason to call the different choice of $\xi$ a choice of gauge. Indeed the different $\xi$ corresponds to the different gauge parameter $\lambda$ for
$$\partial_\mu A^\mu = \lambda$$
You may google for
R$_\xi$ gauge.
