If light is energy, then according to $E =mc^2$, it should have mass. My reasoning is that if light has speed, and it is a form of energy, it must have mass, otherwise how can it satisfy the equation?
Have you looked at the formula for the famous m in
So in the Lorenz transformation system of special relativity , when the velocity of a particle approaches the speed of light, m becomes undefined, i.e. 0/0 for a zero mass particle.
m as dependent on velocity cannot characterize a particle in a one to one correspondence. What characterizes a particle is m_0, the invariant mass, which is the "length" of the Lorenz energy momentum four vector
So your reasoning is not considering all the mathematical consequences of Lorenz transformations.
The zero invariant mass of the photon is consistent with observations and the Maxwell equations for light, which consists of innumerable photons.
- 236,935
The term "mass" has two meanings here. Each particle has a rest mass $m_0$ such that $E^2=m_0^2c^4+c^2p^2$ with $p=\frac{Ev}{c^2}$ the momentum. For light, $v=c$ so $cp=E$ so $m_0=0$. Rest mass is also called invariant mass because it's unchanged by a Lorentz transformation such as a frame shift, whereas $E,\,p$ are not. Indeed, the rearrangement $m_0^2c^2=p^\mu p_\mu$ with $p^0:=\frac{E}{c}$ makes this manifest.
- 25,615
