Is there a limit to the mass of a chemical rocket leaving for earth orbit in a single stage?
Payload, fuel, structure ... all things considered.
Uzer
  • 197
There is no hard limit to the mass, but practically speaking, for existing rocket fuels, $v_e\,\ln(\frac{m_0}{m_f})$ is limited to speeds well below escape velocity. Maximum fuel fractions are of the order of perhaps 98% or so, since you are going to need some mass for the structure of the rocket and its engines. You could achieve very high $v_e$ with non-chemical rockets, but those typically require a lot more structure. Bottom line is that at the current state of the art, you cannot really make it into orbit with a single-stage rocket, unless you have an air-breathing engine so you can take the oxidant part of your fuel from the atmosphere.
Pirx
  • 3,803
