As we all known, the fundamental force between objects (such as Gravitation Force, Coulomb Force) can be either attractive or repulsive. But I am curious about the intermolecular force
$$ f = \dfrac{\mu}{r^s}-\dfrac{\lambda}{r^t} \quad (\mu,\lambda,s,t >0 \quad \text{and} \quad s >t)$$
can be both attractive and repulsive depend on the relative distance between molecules(illustrated by the following figure)?
Why the distance between molecules can mediate the symbols (minus for attractive and plus for repulsive) of force? How does one can explain this curve occurs just from the fundamental force? (in which I think there exists only the Coulomb' force, of course, it can be attractive or repulsive.)
Jack
  • 1,847
The most typical example of such a potential is the Lennard-Jones potential: $$ V = -\left(\frac{r_0}{r}\right)^6+\left(\frac{r_0}{r}\right)^{12}$$ This is repulsive at very short distances, but attractive at large distances, as you said in your question. In fact the Lennard-Jones potential is a mathematically simple guess based on these assumptions.
But why do we expect such behaviour? Even though an atom or a molecule is electrically neutral overall, the charge might be distributed unevenly (you can think of it as having a positively charged and a negatively charged part). This uneven distribution may be due to quantum fluctuations for atoms, or to the molecular structure for molecules. Anyways, it gives rise to a dipole moment, usually called $p$, which in turn produces an electric field $E \propto p/r^3$. Now, this field will induce a dipole moment $p'$ in another molecule so that $p' \propto E \propto p/r^3$. The potential energy of two dipoles scales like $p p' /r^3$ therefore giving rise to the $1/r^6$ potential.
On the other hand, when two atoms come really close together, two things happen: first of all, the subatomic structure becomes relevant, for instance in the form of electrons in the outer shells repelling each other; another effect which will be relevant is the Pauli exclusion principle, which roughly speaking in this case prevents two particles from occupying the same space. The reason why we pick $12$ as the exponent is probably due to convenience for calculations more than any other physical reason.
John Donne
  • 5,009
  • 18
  • 31
-1
This is actually a question of interaction of atoms Let consider two atoms both at infinity ... here we consider that there is no interactive force
In atoms forces existing are 1. Repulsive forces:- a) Electron-electron repulsion b)Nucleus-Nucleus repulsion
2.Attractive forces:- a).Nucleus-electron attraction
Up to point of minima attractive forces dominate while from zero distance point to minimum distance point repulsive forces dominate than attractive forces.
I you find this answer helpful please up vote this answer.
Het
