-4
So basically I have this idea, we can't see how does an electron really move because of its small size and the wavelength of light being comparatively being much larger. What if we took two spheres (which are macroscopic that is can be seen with the naked eye), one more massive than the other and having a mass ratio of 15368.5978977 (exact ratio between the mass of a proton to that of an electron). Now we gave the massive sphere a +e charge(positive electronic charge) and the less massive sphere a -e charge(the electronic charge).
Now we suspend the macroscopic proton model (M.P.M) in a vacuum (suppose outer space) in absence of any significant gravitational field. Then we shoot the macroscopic electron model (M.E.M) towards the M.P.M with such a velocity that when it finally arrives in the M.P.M electric field, its Electrical PE + Motional KE is exactly equal to that of an electron in the hydrogen atom.
Now if the electric, gravitational forces are the same, shouldn't the M.E.M move around the M.P.M exactly like an electron does around the nucleus in the hydrogen atom?
Batwayne
  • 313
We do not have to do your experiment because it can be described by classical electrodynamics, and classical electrodynamics is so very well validated macroscopically that it is not very smart to make models when the mathematics is there.
The solution does not describe what is happening with the hydrogen atom, which is one of the reasons quantum mechanics had to be invented in place of classical mechanics. In classical mechanics and electrodynamics there is no stable system of two charges the way you describe, whereas the hydrogen atom is stable. The two charges in your classical model will attract each other and fall on each other neutralizing the charge while at the same time radiating away energy continuously.
The Bohr model was invented to stop this destructive scenario, since the hydrogen atom was stable. So to start with stability was imposed by postulates so that the series fitting the radiation spectra of the hydrogen atom could be arrived at. Quantum mechanics with its postulates fitted these spectra using the Schrodinger equation.
In quantum mechanics only the probability of the existence of a particle with a given (x,y,z) can be predicted and known. An average momentum from the energy of the hydrogen energy level may be estimated, but the electron is not in an orbit, but in an orbital, a probability locus..
anna v
  • 236,935
An electron doesn't move around the nucleus in a hydrogen atom, so no.
Why don't electrons crash into the nuclei they "orbit"?
OrangeDog
  • 227
You can temporarily excite one electron of an atom to a very high quantum number $n$, which is called a Rydberg atom. When an electron is in this state, it behaves much like a classical particle. A macroscopic model like you propose would behave classically.
