Elementary spin 1/2 particles vary in electric charge from o(neutrinos), 1/3(anti-down-, anti-strange-, and anti-bottom-quark), 2/3(up-, charm-, and top-quark), to 1 (electrons, muons and taus). Besides them, there is the hypothetical X-boson which carries 4/3 of one unit electric charge (and which comes together with the hypothetical Y-boson, carrying a charge of 1/3).
Aren't these charges a sign that there exist truly elementary particles with charge 1/3, and charge 0, out of which the particles with a charge from 0 to 4/3 can be formed? In this context, the "elementary" particle with a charge of 1/3 isn't the anti-down-quark, but a combination of these truly elementary particles, so that they give a 1/3 charged anti-down-quark (0,0,1/3).In which case you can assign the 1/3 charged particle a charge 1, in which case quarks have charge -1(1) and 2(-2), and the electron charge-3(3).
Deschele Schilder
  • 45
  • 105
If I understand it correctly, you're asking
The electric charge of all known particles is an integer multiple of one third of the electron's charge. Does that prove the existence of an elementary particle, call it the chargino, which carries an electric charge of one third of the electron's charge, and which is the only elementary particle with a negative electric charge, and that all currently known charged particles are not elementary but composed of charginos, anti-charginos and other elementary particles? The electron would thus contain three charginos, the down quark one, and the up quark two anti-charginos.
No, it does not prove that.
However, it might be viewed as a hint for such a theory. After all, if a 19th-century physicist suddenly discovered that every atom has a core whose electric charge is an integer multiple of the hydrogen core's charge, such a physicist might conjecture the existence of the proton based on that discovery.
Note however that in modern physics there is another explanation for the fact that the electric charge is quantized. In the language of mathematical physics, the electric charge of a particle is determined by which representation it transforms under the $U(1)$ gauge group in the Standard Model. The irreps of $U(1)$ are $\rho(\phi)=\mathrm{e}^{in\phi}$ with an $n\in\mathbb Z$. This $n\in\mathbb Z$ determines the electric charge by $e=\frac n3$.
If you didn't understand that, imagine the electric charge being something like a participation in some process involving a cord which is wound several times around a lamp pole (this is just an analogy, don't take it too literally, there are not any real cords involved). If it's wound clockwise, the particle's charge is $-1/3$ (for example the down quark). If it's wound twice counter-clockwise, the particle's charge is $+2/3$ (the up quark). Three times clockwise would be $-1$, the electron. If it's not wound around the pole, the particle is electrically neutral, for example the neutrino. For composed particles, you simply sum over the constituents' number of loops.
You see, because it's forbidden to wind the cord around half of the pole, you get a quantized (integer) electric charge.
The modern explanation is in many ways better than the "chargino theory" mentioned above. The Standard Model has been confirmed by countless experiments, but AFAIK there is no single experiment that contradicts it.
Bass
  • 1,527
