-7
So, I've been trying to learn a lot of physics and teach myself it. But recently I came across a problem. When I read through Einstein's field equation in mathematical form, I noticed there's an $8\pi$. What does this mean? Why is it there
$$\large {} R_{\mu\nu}-\dfrac{1}{2}g_{\mu\nu}R+g_{\mu\nu}\Lambda=\dfrac{8\pi G}{c^4}T_{\mu\nu}$$
Thanks so much! All helps appreciated!
By the way, please explain the reason for the downvotes so I can ask a better question later.
Nevermind, thanks so much guys! I guess my thought was mostly right. Thank you so much for that comment
The $8\pi$ appears when you take the classical limit of the field equations.
Let's suppose we have derived the field equations through the variational principle \begin{equation} \delta S = \delta \int_\Omega \mathcal{L} \sqrt{-g} \ d^4x = 0, \end{equation} we can separate the lagrangian into a term that corresponds to matter-energy ($\mathcal{L}_M$) and another that corresponds to the gravitational field ($\mathcal{L}_G$), so that we write \begin{equation} \mathcal{L} = \mathcal{L}_G - 2 \ \kappa \ \mathcal{L}_M. \end{equation} $\mathcal{L}_G = R$ ($R$ is the curvature invariant), that gives us the the Einstein-Hilbert Action. \begin{equation} \delta S = \delta \int_\Omega \left( R - 2 \kappa \mathcal{L}_M \right) \sqrt{-g} \ d^4x = 0 \end{equation} Subtituting the above equation in the action, you get: \begin{equation} R_{\mu \nu} - \frac{1}{2} R g_{\mu \nu} = \kappa T_{\mu \nu}, \end{equation} where $T_{\mu \nu}$ is the Stress-Energy tensor, and depends on $\mathcal{L}_M$.
Since Newtonian mechanics is very well tested, it's expected that it's a limit case of this equation, so we assume a weak field approximation: the Minkowski metric ($\eta_{\mu \nu}$) is under a small perturbation ($h_{\mu \nu}$ and the the mass is perfect fuild ($T_{\mu \nu} \approx T_{00} = \rho c^2$).
\begin{equation} g_{\mu \nu} = \eta_{\mu \nu} + h_{\mu \nu}. \end{equation}
If you work with this, you arrive at: \begin{equation} \frac{\partial^2 h_{00}}{\partial x^k \partial x^k} =\kappa \rho c^2 \end{equation}
Comparing with the Newtonian equation for the potencial (Poisson's equation): \begin{equation} \frac{\partial ^2\Phi}{\partial x^k \partial x^k} = 4 \pi G \rho \end{equation}
Then, we can assume that $h_{00} = \frac{2}{c^2} \Phi$ (The $1/c^2$ term is necessary to adjust the dimensions) and, therefore, $\kappa = 8 \pi G/c^4$: \begin{equation} R_{\mu \nu} - \frac{1}{2} R g_{\mu \nu} = \frac{8 \pi G}{c^4} T_{\mu \nu}. \end{equation}
Nothing to do with dimensions.
(Since you said you are studying GR, I am assuming you kind of know topics like curvature invariant and variational principle).
matrp
  • 788
