I have read this Question:
What is the general relativity explanation for why objects at the center of the Earth are weightless?
And John Rennie's answer where he says:
"When $r = 0$ the Christoffel symbol $\Gamma_{tt}^r$ is zero and that means the radial four-acceleration is zero and that means you're weightless."
And this Question:
Gravitational time dilation at the earth's center
And Luboš Motl's answer where he says:
"If you spend 1 billion years at the center of the Earth, your twin brother outside the gravitational field will get 1 billion and one years older. If you wish, you may interpret it by saying that it's healthy to live at the center of the Earth. Good luck."
So what the two are saying is that at the center of mass:
  • there is time dilation
  • there is no curvature
I read and understand what they are writing about the Christoffel symbol
$$\Gamma_{tt}^r= \frac{r}{2R^6}\left[2M^2r^2+MR^3\left(3\sqrt{1-\frac{2Mr^2}{R^3}}\sqrt{1-\frac{2M}{R}}-1\right)\right] $$
And the potential at the center, assuming uniformity, is
$$ \Phi = -\frac{GM}{R_E} - g(R_E) \frac{R_E}{2} = -\frac 32 \frac{GM}{R_E} = -\frac 32 g(R_E) R_E $$
And that
"This gravitational potential determines the slowing of time, too."
And somehow I just cannot understand how it is possible to have time dilation without curvature. I thought that time dilation is caused by (in GR, not SR) curvature, which is the effect of gravity, the gravitational potential.
I don't understand how there can be gravitational potential without curvature, I thought the only effect gravity has is the curvature of spacetime.
  1. Can somebody please explain how (with math and with simple way too) how that is possible together? How can there be gravitational potential and time dilation without curvature?
  2. Isn't gravity's only effect the curvature? Is there another effect with what gravity can create potential (so without creating curvature) and so create time dilation?
Time dilation is not a local property. That is, you can't just take a point in space and say what it's time dilation is. Time dilation is always relative to some other point in space.
Suppose we take two points $A$ and $B$, then time dilation means that for the coordinate time $t$ we have:
$$ \frac{dt}{d\tau}(\text{at point A}) \ne \frac{dt}{d\tau}(\text{at point B}) $$
and the time dilation isn't determined by what happens at $A$ or what happens at $B$, but by what happens in between $A$ and $B$. In particular it's possible for spacetime to be flat at point $A$ and flat at point $B$, and there can still be time dilation if the spacetime is curved in between points $A$ and $B$.
To take a concrete example lets consider a thin spherical shell of mass $M$ and radius $D$. Outside the shell the metric is simply the Schwarzschild metric, so if we go out to $r=\infty$ spacetime is flat.
Inside the shell the metric is:
$$ ds^2 = -\left(1 - \frac{2GM}{c^2D}\right) c^2dt^2 + \frac{dr^2}{1 - \frac{2GM}{c^2D}} $$
where for simplicity I'll leaving off the angular bit since we dealing only with spherically symmetric systems. At first glance this looks curved, but we can define new time and radial coordinates:
$$\begin{align} T &= \sqrt{1 - \frac{2GM}{c^2D}}\,t \\ R &= \frac{r}{\sqrt{1 - \frac{2GM}{c^2D}}} \end{align}$$
and using these coordinates the metric becomes:
$$ ds^2 = -c^2dT^2 + dR^2 $$
and this is just the Minkowski metric in polar coordinates. So spacetime is flat inside the spherical shell, which should come as no surprise since it's just Newton's shell theorem.
However even though spacetime is flat inside the shell, the flat time coordinate $T$ is not the same as the time coordinate $t$ outside the shell at $r=\infty$. They differ by a factor of $\sqrt{1-2GM/c^2D}$, and that means the time inside the shell is dilated i.e. runs slower, than the time at infinity:
$$ \frac{dT}{dt} = \sqrt{1-\frac{2GM}{c^2D}} $$
This gives you an example of two points, both in flat spacetime, that have a relative time dilation. This difference in the time coordinates is due to the spacetime curvature caused by the shell in between the points inside and outside the shell.
John Rennie
  • 367,598
Equation (1) in John Rennie's answer is
$$ ds^2 = -\left[\frac{3}{2}\sqrt{1-\frac{2M}{R}} - \frac{1}{2}\sqrt{1-\frac{2Mr^2}{R^3}}\right]^2dt^2 + \frac{dr^2}{\left(1-\frac{2Mr^2}{R^3}\right)} + r^2 d\Omega^2 \tag{1} $$
which is, we are told, the Schwarzschild interior metric for a spherical body of uniform density. At the center, where $r=0$, this line element becomes
$$ ds^2 = -\left[\frac{3}{2}\sqrt{1-\frac{2M}{R}} - \frac{1}{2}\right]^2dt^2 + \frac{dr^2}{\left(1-\frac{2Mr^2}{R^3}\right)}$$
Assuming one remains at $r=0$, we have that
$$d\tau = \left[\frac{3}{2}\sqrt{1-\frac{2M}{R}} - \frac{1}{2}\right]\,dt$$
so, a clock at the center runs slower than a clock 'at infinity' by a factor of
$$\frac{d\tau}{dt}=\left[\frac{3}{2}\sqrt{1-\frac{2M}{R}} - \frac{1}{2}\right]$$
So, there is time dilation at the center according to this line element. Note that for $M \rightarrow 0$, the clock at the center runs at the same rate as the clock at infinity.
It's not clear to me what you mean by "there is no curvature". Spacetime curvature is manifest in geodesic deviation which is to say that, if there's curvature, two nearby geodesics that are initially parallel will not remain parallel.
And that is the case here. A particle that remains at $r=0$ is on a geodesic. A nearby freely falling particle at $r=\epsilon$, initially at rest with respect to the other particle, will fall towards the other particle which means there is curvature.
From the comments:
What I do not understand is #1 is the particle at rest at the center really on a geodesic, then why is it not moving in space (if it is not moving in space, that means it is still 'moving' in the time dimension at speed c, I understand that)
A timelike geodesic $x^\mu(\tau)$ satisfies the geodesic equation
$$\frac{d^2x^\mu}{d\tau^2}=-\Gamma^\mu_{\;\alpha\beta}\frac{dx^\alpha}{d\tau}\frac{dx^\beta}{d\tau}$$
Consider the world line of a (massive) particle given by $x'^\mu(\tau)=(t,0,0,0)$. Since $\frac{d^2x'^\mu}{d\tau^2}=0$, then $x'^\mu(\tau)$ is a geodesic if $\Gamma^\mu_{\;tt}=\frac{1}{2}g^{\mu\nu}(g_{\nu t,t}+g_{\nu t,t}-g_{tt,\nu})|_{r=0}=0$
By inspection, the metric depends only on the coordinate $r$ and so we need to evaluate
$$\Gamma^r_{\;tt}=-\frac{1}{2}g^{\mu\nu}g_{tt,r}|_{r=0}$$
But, in John Rennie's answer, this evaluates to zero thus a world line given by $(t,0,0,0)$ is a geodesic; a particle that remains at $r=0$ is in free fall.
I'd like to add a comment to Alfred's correct answer and all the correct answers you cite.
Something to emphasize here, and which I believe is causing problems for your understanding, is that weightlessness and curvature are about different terms in the Taylor series for the metric (and other geometric properties) of spacetime when we expand these objects in geodesic (Riemann normal) co-ordinates. Weightlessness is a first order notion: you can understand it by expanding the Taylor series to first order. Curvature, on the other hand, is a second order or (as it is often called) a tidal notion.
At any point in spacetime (curvature present or not), we can always make it look Minkowskian if we restrict ourselves to a small enough neighborhood of that point: that's just part and parcel of the manifold as the geometric object describing spacetime in GTR. And it is in this restricted view that we define weightlessness: there is always has a momentarily comoving inertial frame (a particular choice of basis for the tangent space) wherein an observer is weightless; but in this case when people say things are weightless at the Earth's center, what they are emphasizing is that this comoving frame is stationary relative to the Earth's center, i.e. relative to the stuff that makes the Earth up.
The curvature / geodesic deviation is about how the true picture deviates from this localized one as we shift over length / timescales greater than the ones whereover the first order picture, given by the linear tangent space, holds good. So these tidal effects only show up in the second order terms of the relevant Taylor series.
As for any Taylor series, I hope that you can understand that the first and second order co-efficients can be set wholly independently.
Selene Routley
  • 90,184
  • 198
  • 428
