I've read here that microwaves are blocked by the holes in a microwave window because the holes on the door are small enough to prevent the microwaves from passing through. However, if wavelength is only the distance between successive crests of a wave, why should that decide what a certain wave can fit through? Why is amplitude not the deciding factor and is there a way to explain this visually?
Asked
Active
Viewed 505 times
