My question comes from reading about distances on Wikipedia, and seeing the phrasing Variational formulation of distance. I am not very comfortable with vector notation, so I've rephrased the math slightly (hope it is correct).
Basically, the Euclidean distance between two points on $\mathbb{R}$ $A$ and $B$ can be written in variational form where the distance is the minimum value of an integral:
$$D=\int_0^T\sqrt{\left( \frac{\partial|h^*-h_t|}{\partial t}\right) ^2}dt$$
where $|h^*-h_t|$ is the simple (Euclidian) distance between two points at time $t$. This distance is the minimal value of the integral when $h^*=h_t$.
Questions:
  1. Is my reformulation done correctly?
  2. Why, intuitively, is the above formulation a partial derivative with respect to time?
  3. How would this look if generalised to $\mathbb{R}^n$, still keeping my naïve and space consuming notation?
  4. Is there a simple way to prove that the integral is at its minimum when $h^*=h_t$?
  5. How does this, intuitively, relate to the principle of least action?
This is a crosspost from Math.SE, but I think that the question is closer to physics.
tmo
  • 103
  1. No, when adding $h^*(t)$, you are modifying the integrand which is not anymore equal to speed $\times$ time increment, which it should be. Besides, you added an unnecessary $t$ subscript to $h$.
  2. It is wrongly written as partial derivative, there is only one argument in $h$ so you can write as well $\frac{d}{dt}$.
  3. The wikipedia article is already written in $\mathbb{R}^n$ (see arrow on $r$), you wrongly interpreted it as being in $\mathbb{R}$.
  4. the integral (the correct one from the wikipedia article) is at its minimum when $h=h^*$ by the very definition of $h^*$.
  5. It relate to the principle of least action because the varying integral is minimized.
