My book claims that in vacuum, the total energy density of the electromagnetic field is equally shared between electric and magnetic fields by explicitly showing that $$\frac{1}{2}\epsilon_0 \textbf{E}^2=\frac{1}{2}\frac{\textbf{B}^2}{\mu_0}.$$
$\bullet$ However, one can change to a different inertial frame by a Lorentz boost where $\textbf{E}$ or $\textbf{B}$ will mix up. Is this statement a Lorentz invariant assertion? If not, does it imply we are in a special Lorentz frame (not violating relativity, of course!) in which this claim is true?
$\bullet$ Is it possible to go a frame in which one of the fields ($\textbf{E}$ or $\textbf{B}$ ) of an EM wave is made to vanish? Then it is clear that the above claim is meaningless.
SRS
  • 27,790
  • 13
  • 115
  • 365
The answer to the question in the title is yes. There are two fundamental Lorentz invariant scalars of the EM field,
$$\frac12F^{\mu\nu}F_{\mu\nu}=\mathbf{B}^2-\mathbf{E}^2$$ and $$\frac14F_{\mu\nu}\ {}^\ast F^{\mu\nu}=\frac14\epsilon^{\mu\nu\alpha\beta }F_{\mu\nu}F_{\alpha\beta}=\mathbf{B}\cdot\mathbf{E}$$
(modulo units and constants). The former reflects exactly the equal-energy-density property of electromagnetic radiation, and it guarantees that if $\mathbf B ^2 = \mathbf E^2$ in one frame, then that stays true in all frames of reference.
In general, for radiation, the equal sharing is at least morally true, and it's easy to verify for plane-wave radiation. On the other hand, there are plenty of fields for which energy is not equally shared, with the simplest example being the electrostatic field of a point charge.
Moreover, for homogeneous fields (or locally for inhomogeneous fields) any two configurations that share those two invariants are almost certainly connected by a Lorentz transformation (but check for a proof before you take my word for it).
Emilio Pisanty
  • 137,480
I strongly doubt this claim: you can choose initial fields (at some initial time point in the entire 3d space) arbitrarily (provided divergence of electric and magnetic field vanishes). The claim is true, however, for a plane (sinusoidal) electromagnetic wave, and this does not depend of the (inertial) frame of reference, as $E^2-B^2$ is a Lorentz invariant.
akhmeteli
  • 27,962
