138
The Feynman lectures are universally admired, it seems, but also a half-century old. Taking them as a source for self-study, what compensation for their age, if any, should today's reader undertake? I'm interested both in pointers to particular topics where the physics itself is out-of-date, or topics where the pedagogical approach now admits attestable improvements.
The Feynman Lectures need only a little amending, but it's a relatively small amount compared to any other textbook. The great advantage of the Feynman Lectures is that everything is worked out from scratch Feynman's way, so that it is taught with the maximum insight, something that you can only do after you sit down and redo the old calculations from scratch. This makes them very interesting, because you learn from Feynman how the discovering gets done, the type of reasoning, the physical intuition, and so on.
The original presentation also makes it that Feynman says all sorts of things in a slightly different way than other books. This is good to test your understanding, because if you only know something in a half-assed way, Feynman sounds wrong. I remember that when I first read it a million years ago, a large fraction of the things he said sounded completely wrong. This original presentation is a very important component: it teaches you what originality sounds like, and knowing how to be original is the most important thing.
I think Vol. I is pretty much OK as an intro, although it should be supplemented at least with this stuff:
  1. Computational integration: Feynman does something marvellous at the start of Volume I (something unheard of in 1964), he describes how to Euler time-step a differential equation forward in time. Nowadays, it is a simple thing to numerically integrate any mechanical problem, and experience with numerical integration is essential for students. The integration removes the student's paralysis: when you are staring at an equation and don't know what to do. If you have a computer, you know exactly what to do! Integrating reveals many interesting qualitative things, and shows you just how soon the analytical knowledge painstakingly acquired over 4 centuries craps out. For example, even if you didn't know it, you can see the KAM stability appears spontaneously in self-gravitating clusters at a surprisingly large number of particles. You might expect chaotic motion until you reach 2 particles, which then orbit in an ellipse. But clusters with random masses and velocities of some hundreds of particles eject out particles like crazy, until they get to one or two dozen particles, and then they settle down into a mess of orbits, but this mess must be integrable, because nothing else is ejected out anymore! You discover many things like this from piddling around with particle simulations, and this is something which is missing from Volume I, since computers were not available at the time it was written. It's not completely missing, however, and it's much worse elsewhere.
  2. The Kepler problem: Feynman has an interesting point of view regarding this which is published in the "Lost Lecture" book and audio-book. But I think the standard methods are better here, because the 17th century things Feynman redoes are too specific to this one problem. This can be supplemented in any book on analytical mechanics.
  3. Thermodynamics: The section on thermodynamics does everything through statistical mechanics and intuition. This begins with the density of the atmosphere, which motivates the Boltzmann distribution, which is then used to derive all sorts of things, culminating in the Clausius-Clayperon equation. This is a great boon when thinking about atoms, but it doesn't teach you the classical thermodynamics, which is really simple starting from modern stat-mech. The position is that the Boltzmann distribution is all you need to know, and that's a little backwards from my perspective. The maximum entropy arguments are better--- they motivate the Boltzmann distribution. The heat-engine he uses is based on rubber-bands too, and yet there is no discussion of why rubber bands are entropic, or of free-energies in the rubber band, or the dependence of stiffness on temperature.
  4. Monte-Carlo simulation: This is essential, but it obviously requires computers. With Monte-Carlo you can make snapshots of classical statistical systems quickly on a computer and build up intuition. You can make simulations of liquids, and see how the atoms knock around classically. You can simulate rubber-band polymers, and see the stiffness dependence on temperature. All these things are clearly there in Feynman's head, but without a computer, it's hard to transmit it into any of the students' heads.
For Volume II, the most serious problem is that the foundations are off. Feynman said he wanted to redo the classical textbook point of view on E&M, but he wasn't sure how to do it. The Feynman Lectures were written at a time just before modern gauge theory took off, and while they emphasize the vector potential a lot compared to other treatments of the time, they don't make the vector potential the main object. Feynman wanted to redo Volume II to make it completely vector-potential-centered, but he didn't get to do it. Somebody else did a vector-potential based discussion of E&M based on this recommendation, but the results were not so great.
The major things I don't like in Vol. II:
  1. The derivation of the index of refraction is done by a complicated rescattering calculation which is based on plum-pudding-style electron oscillators. This is essentially just the forward-phase index-of-refraction argument Feynman gives to motivate unitarity in the 1963 ghost paper in Acta Physica Polonika. It is not so interesting or useful in my opinion in Vol. II, but it is the most involved calculation in the series.
  2. No special functionology: While the subject is covered with a layer of 19th-century mildew, it is useful to know some special functions, especially Bessel functions and spherical harmonics. Feynman always chooses ultra special forms which give elementary functions, and he knows all the cases which are elementary, so he gets a lot of mileage out of this, but it's not general enough.
  3. The fluid section is a little thin--- you will learn how the basic equations work, but no major results. The treatment of fluid flow could have been supplemented with He4 flows, where the potential flow description is correct (it is clear that this is Feynman's motivation for the strange treatment of the subject, but this isn't explicit).
  4. Numerical methods in field simulation: Here if one wants to write an introductory textbook, one needs to be completely original, because the numerical methods people use today are not so good for field equations of any sort.
Vol. III is extremely good because it is so brief. The introduction to quantum mechanics there gets you to a good intuitive understanding quickly, and this is the goal. It probably could use the following:
  1. A discussion of diffusion, and the relation between Schrödinger operators and diffusion operators: This is obvious from the path integral, but it was also clear to Schrödinger. It also allows you to quickly motivate the exact solutions to Schrodinger's equation, like the $1/r$ potential, something which Feynman just gives you without motivation. A proper motivation can be given by using SUSY QM (without calling it that, just a continued stochastic equation) and trying out different ground state ansatzes.
  2. Galilean invariance of the Schrödinger equation: This part is not done in any book, I think only because Dirac omitted it from his. It is essential to know how to boost wavefunctions. Since Feynman derives the Schrödinger equation from a tight-binding model (a lattice approximation), the galilean invariance is not obvious at all.
Since the lectures are introductory, everything in there just becomes second nature, so it doesn't matter that they are old. The old books should just be easier, because the old stuff is already floating in the air. If you find something in the Feynman Lectures which isn't completely obvious, you should study it until it is obvious--- there's no barrier, the things are self-contained.
Drarp
  • 435
I'm not sure what you mean by saying: "the physics is out-of-date," because in some sense Newtonian mechanics is out-of-date. But we know that it is an effective theory (the low-speed limit of relativity) and is important to study and understand since it describes everyday-life mechanics accurately.
Feynman lectures are the classic 101/102 physics resource. So, just read and learn. And Feynman is a master in his pedagogical approach (remember the challenger case?)
The only thing is that you're not going to learn the techniques of Quantum field theory or other advanced and more recent research-level topics from Feynman lectures.
stupidity
  • 1,181
