For $\mathcal{N}=2$ 4D Super-Yang-Mills it is easy to find good, precise definitions of "Higgs branches" and "Coulomb branches" in moduli space. The moduli space (of VEVs) of the theory is locally a direct product between the moduli of the vector multiplet and those of the hypermultiplet, and moving along the first is called moving along the Coulomb branch, and along the other moving along the Higgs branch.
However, these terms are also used in situations where we don't have such a neat factorization of moduli space, and even where we don't actually know the moduli space explicitly at all. As an example, consider the following from "The landscape of M-theory compactification on seven-manifolds with $G_2$ holonomy" by Halverson and Morrison:
Suppose there existed a singular limit of $X$ which realizes a [...] gauge group $G\times\mathrm{U}(1)^k$ [...]. If smoothing the manifold back to $X$ Higgses this theory [carries out symmetry breaking by the Higgs mechanism] in a standard way, then an upper bound on the number of $\mathrm{U}(1)$s is set by the dimension of the maximal torus of the gauge theory on the singular space, that is $$ b_2(X) \leq \mathrm{rk}(G) + k \tag{4.1}$$ Certainly, if a gauge enhanced singular limit exists and $b_2(X) = 0$ then the vacuum obtained from M-theory on $X$ is on a Higgs branch; conversely $b_2(X) \neq 0$ is necessary for it to be on a Coulomb branch.
Here $X$ is some 11-dimensional manifold with an Abelian gauge theory on it that goes to a singular manifold in some limit, and there are general arguments to expect this singular limit to carry a non-Abelian gauge theory, meaning that the reverse direction from the singular limit to the smooth $X$ corresponds to symmetry breaking of some sort. $b_2(X)$ denotes the second Betti number. In general, the exact characteristics of the gauge theory (such as the number and type of multiplets) are difficult to determine and rarely explicitly known, which means the naive definition of Coulomb and Higgs branches from the 4D case does not apply since we don't know the full moduli space.
So, what is the general definition of these two branches that can also be applied to higher-dimensional theories with arbitrary $\mathcal{N}$? (In this case it would be $\mathcal{N}=1$, if that's relevant)
I suspect that the "Higgs branches" are just cases where the gauge theory is completely broken and that the "Coulomb branches" are those where the non-Abelian symmetry gets broken to a $\mathrm{U}(1)^n$.
There's a related question here but I can't really tell whether it is asking the same or what the answer is trying to say.
There's also this unanswered question which asks however for the reason for the nomenclature and specific properties of the branches, while I am solely interested in their actual definition for now.
