I've been following the EPFL lecture notes in advanced QFT, mainly chapter 2 which involves effective potential calculations, because it's important for my thesis, and I'm looking for some clarification on the concepts presented there.
First, I'd like to know what the "second functional derivative" (like $\displaystyle \frac{\delta^2 S[\phi]}{\delta\phi(x)\delta\phi(y)}$) is, and how can I compute it (rigorously, I'm afraid the hand-wavy way some physicists do it isn't exactly clear to me) for, say, the standard quartic self-interaction Lagrangian:
$\displaystyle S[\phi]=\int d^4x \left[\frac{1}{2}\partial_\mu\phi\partial^\mu\phi-\frac{1}{2}m^2\phi(x)^2-\frac{\lambda}{4!}\phi(x)^4\right]$
The main issue I have is with the derivative term, I'm guessing something doesn't commute properly, and if I'm not mistaken, the second functional derivative of the other parts is:
$\displaystyle \frac{\delta^2 S_{non-derivative}[\phi]}{\delta\phi(x)\delta\phi(y)}=-m^2\delta^4(x-y)-\frac{\lambda}{2}\phi^2(y)\delta^4(x-y)$
As an aside, how to compute the functional derivative(s) of that? Do I just treat the deltas as constants, so we end up with products of deltas?
Second, I'm having trouble following the actual computation of the trace (eq. 2.39):
$tr\log\left(\Box+m^2+\frac{\lambda}{2}\phi^2\right)$
How exactly is this trace defined, as we're dealing with differential operators? The author says he will use a plane wave basis, whatever that means (I'm guessing those are the eigenfunctions of the operator under the log), and, for reasons unclear to me, treats $\phi^2$ as a constant, while from the functional derivative we see that it has some spacetime dependence other than the delta function, how does that work? Frankly, I'm quite confused, and any guidance would be appreciated, especially if it's more mathematically rigorous.
blueshift
  • 358
