Please don't mark as duplicate. I am asking specifically for the 4vektor formula to see at speed c in space, I will get 0 for the time dim.
I was reading this question:
4 dimensional interpretation
specifically the #2 question
"If a body is at rest in the classical 3 dimension, it would travel through time at cc, but if traveling at cc in space, it would be resting in the "time" dimension.."
I understand the first part. But specifically my question is about this part:"but if traveling at cc in space, it would be resting in the "time" dimension"
And John Rennie's answer where he says
"As it happens, you are absolutely correct."
v⃗ =(c(dt/dτ),dx/dτ,dy/dτ,dz/dτ)
I understand that if I am at rest in space then I am still moving at speed c in time. The magnitude is always c. But I don't understand if I am moving at speed c in space, how can the four-velocity explain that I am at rest in time, so my time component c(dt/dτ) is 0?
Question:
  1. How can you explain with the four-velocity that when something is moving at speed $c$ in space, then it is at rest in time?
